Question about Whirlpool Ovens
Light glows but oven doesnt light - Whirlpool Ovens
  • 9 Answers
Im not fully confident this is a good answer but your oven may work just it wont light i would something simple in and see if it will cook
Posted on Feb 19, 2009
Oven does not ignite broiler does ignite burners do ignite
the ignitor should pull 2.8 amps or more. it can lite but not release gas. just beacuse it is glowing doesnt mean its good. check amp draw w/ meter if less than 2.8 amps. change it out. if doesnt glow or draw any amps. check to be sure have 120v. then change ignitor.
Aug 04, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Oven will not light. igniter is coming on and glowing orange but no gas is coming through the tubing. burners are getting gas however so there is gas coming through the line. Burners light oven doesnt
maybe your oven holes are jam with grease, common in gas operations. If not; you will have to check the oven line (gas) it self , maybe a kink or something like it. Or it may have a solenoid that is not switching on.
Nov 14, 2009 | Ovens
Oven lights sometimes and sometimes it doesnt
Replace the glow bar ignitor. It is weak.
Aug 27, 2009 | Maytag Ovens
Oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Aug 17, 2009 | Ovens
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Can I still light an oven even if the electric pilot doesnt work
Looks like your oven has a "glow" coil. That being the case, you will not be able to light the oven without power. It has to glow to open the valve, and there is no override for this. Sorry.
About the cord, you could install a plug on the cord, or simply replace the cord. (I realize you say you are trying to get one). Other than this, turkey on the grill is always good.
Mr Boo
Nov 20, 2008 | Tappan 30IN ELEC IGNa Oven
It is an electric oven.
It doesn't have a hot surface glow ignitor????
Do you mean it doesn't have a hot surface glow indicator???
AND?Whats your question?
Sep 06, 2008 | Ovens
OVEN NOT WORKING
is this a gas stove if so and the bake burner doesnt light then you need a new ignitor and remember just because it glows doesnt mean its ok it has to draw 3 amps to open the gas valve let me know how you make out please
Sep 13, 2007 | Ovens
Ovens Logo
49 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
