Question about Transcend Electronics - Others
The problem is that when we save or delete files :the note; the disk is write protected. how do i remove the write protection of the usb?
    Scholar:
  • 77 Answers
Download this small file:
http://www.kellys-korner-xp.com/regs_edits/writeenable.reg
Save the file on your desktop. Then double click the writeenable.reg file and click on Yes when Windows asks if yo u want to write to registry.
That;s it. Now you can try to create a new folder on your usb drive and it should be created. That means it's now normal.
You will need to remove the USB and re-plug it or may be a reboot is needed before it will work normally.
HTH,
Regards,
Deboo
Posted on Feb 19, 2009
Cannot remove write protection from pen drive
Write protect can mean:
  • You do not have enough rights to modify. I came from another account.
  • It has an actual dip switch you move up and down.
  • The file is in use.
Dec 11, 2012 | Electronics - Others
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The usb is write protected and no other files can be added to the flash drive because it is write protected.
a usb drive is just like a hard disk drive, You can go to the control panel and remove the write protection by unchecking a box in the menu, then delete all of the files that you don't want, or format the drive.
Nov 12, 2010 | Office Equipment & Supplies
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
How to remove write protect on my usb flash drive
On USB stick, there is a "Lock/Unlock" slide bar on the opposite end of USB port. It uses the symbols of a "lock" and an "open hasp lock" to show that the device is "locked" (write-protected) or "unlocked" or not write-protected. remove the lock
Oct 08, 2008 | Computers & Internet
Write protect problem
what ever file you have copied or going to copy . right click on the file , go in properties and and uncheck read only. this will solve your problem
Jun 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Make sure your mp3 "HOLD" option is not on!
Its really as simple as that. The hold button 'protects' the files.
Nov 24, 2007 | Audio Players & Recorders
how can i delete the files on my flash drive
Nov 15, 2007 | Video Game Consoles & Games
Electronics - Others Logo
78 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
