Question about Linksys Wireless-G WRT54G Router
Cant connect my ps3 to wireless internet - Linksys Wireless-G WRT54G Router
  • Cameron Scott May 11, 2010
    You'll also likely need to enable port forwarding if you expect to play online...check your FAQ for your router online.
  • Ryan Fruto
    Ryan Fruto May 11, 2010
    I assume your PS3 has a wi-fi interface which you've set-up to find your home network? If not, try to "find" it via your PS3. Is your router "broadcasting" its "SSID"? If not, then your PS3 won't find it, and you'll have to manually configure it to work with your router.
    Have you gone into (logged-in) your router to see which wireless devices it's expecting to connect. You'll need to add your PS3's wi-fi adapter as a Trusted Device. Look at your adapter and see if you can find the "MAC Address" written on it. Post back when you do.
    Problem Solver:
  • 18 Answers
You can auto config your network settings on the ps3, make sure you see your wiresless network, if you dont your router is not broadcasting its ssid and you need to activate it by logging into your router from a pc ( in a browser go to "", username is "admin" password ia "admin" or nothing, unless you set up otherwise)
If you dont remember your WEP/WPA code you can find it under "wireless" then "security" in the router once you have gained access as mentioned above.
If all of above is ok then check your IP on your ps3 in settings, network status (i think havent done it in a while) make note of it and go back to the router as mentioned above. click applications and gaming then dmz, enable dmz and type in the ps3 ip, save settings and perform a 30 second reboot to the router (unplug it for 30 seconds) all should be good!
one last note if you have configured everything and you cant connect or it takes ages to do anything, you may need to reposition the router, mine is on the otherside of the room and is working great =p
Posted on Mar 01, 2009
2 Suggested Answers
  • 496 Answers
SOURCE: have wireless router in other room PS3 setup can't connect www
  1. Make sure that your wireless Internet is turned on and working properly.
  2. Step 2 Turn on the Playstation 32.gif game console.
  3. Step 3 Access the "Network Settings" screen under the "Settings" screen in the main menu.
  4. Step 4 Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
  5. Step 5 Select "easy" on the new screen that pops up asking what type of installation you want to use.
  6. Step 6 Select "wireless" when it asks you what type of Internet connection you have.
  7. Step 7 Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
  8. Step 8 Select your home Internet when the screen pops up displaying the available Internet options.
  9. Step 9 Save your settings on the next screen.
  10. Step 10 Test the connection to make sure that it works properly.
Posted on Oct 01, 2009
Why cant connect ps3 to wireless connection WPA-personal?
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-
Dec 19, 2011 | Sony Playstation 3 (PS3) Console
How do I connect my ps3 to the internet and tv so as to view the net on tv?
It's a semi-long process. Do you have a wireless router hooked up to your computer? If so just go to settings then network settings in your ps3 menu. If you have the wireless router then put wireless connection and its straight forward from there. If it is a wired connection and hooked to your ps3 than put wired connection and again its straight forward from there.
Jul 25, 2010 | Sony Playstation 3 (PS3) Console
Cant change wired to wirles on my ps3
Settings->Netwirk Settings ->Internet Connection Settings->Custom and there u can change it :) have Fun
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
I have a PS3 120GB. Recently installed Hi-Def and wireless in home. The wireless router is not in same room with PS3. Is there a device I can add to the PS3 to enable the wireless features, or does it have...
there is already a built in wireless device for the internet. id say its not working because you need to put your I.P adress, subnet mask, router and DNS numbers into playstation. go to settings on ps3. then network settings. manually install all these numbers. you should be able to get them off your laptop or computer when its connected to the internet. if you cant ring your internet provider to grt them.
Jan 10, 2010 | Sony Playstation 3 (PS3) Console
Cant connect my ps3 psp go to the internet using
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. PS3,and PSP use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
I cant hook up my ps3 to the internet
Does the ps3 have wireless antenna to connect to router?
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Ive got verizon wireless broadband for my lap top and cant seem to be able to get online with ps3
Can you provide more information?  The Verizon Wireless broadband access is for your laptop only.  In order for the PS3 to take advantage of it, you'll have to setup Internet Connection Sharing on your laptop. That way your PS3 can connect to your laptop via your laptop's wireless connection (in Ad Hoc mode since you don't have a wifi network) and access the internet via the VzW Broadband Access.
Dec 25, 2008 | Sony Playstation 3 (PS3) Console
No internet connection
Check your network settings and make sure your system is set to wired connection not wireless
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
Sony ps3 online
First off do you have wireless internet you trying to get it connected to or are you using a cord straight to your computer/internet plug in, if its connected to a wi-fi try getting the ps3 closer to the wireless box on you computer, if its connected by a cord try using a different cord as the current one you are using may be faulty
Jan 09, 2008 | Sony Playstation 3 (PS3) Console
Linksys Wireless-G WRT54G Router Logo
187 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
