Question about Acer Aspire 3050-1733 Notebook
Acer 3050 battery doesn't charge and causes CPU to run at 90%
My daughters ACER 3050 suddenly started running the CPU at 90-100% all the time. It was slow to boot up or reboot, the keyboard responded VERY slowly, and basically the computer was useless. The only processes taking lots of CPU time were System idle and NT Kernel. This is odd because when the System idle said it was at 40%, the CPU said it was at 90%.
TO make it short, I finally pulled the battery after noticing the power management was acting weird, flickering between battery and plug-power. This immediately caused the CPU to drop to below 10%.
Would a BIOS flash help?
  • 1 more comment
  • JJD82 Feb 21, 2009
    My problem is very similar. The DVD began running very "herky/jerky" and then it became nearly impossible to log. The computer would not shut down unless I disconnected the battery. I took it to Tigerdirect and they said the problems had to do with some files.
    Took it home and it worked the first time but the same problem came back. I decided to try disconnecting the battery and just run off the power adapter. The computer has run just fine since then.
    I contacted Acer and they said I may need to purchase a new battery but they couldn't tell me if the battery was the problem.
    Do you think it's a battery problem or something else.
    Thank you for your help.
  • deviant00 Mar 02, 2009
    While battery is inserted, this Aspire 1640Z is running at 90% CPU. Touchpad and keyboard stops responding properly, but external USB mouse is not affected. Startup and shutdown times are significantly increased.
    This is on a clean Windows XP SP2 and SP3 installs. I've done a number of installs on this laptop today, but so far I've been unable to link the problem to any particular driver og update.
    Removing the battery immediately solves the problem.
  • hoytpr Mar 04, 2009
    Thank-you Jell587. I will try Malware Bytes tonight. I have already tried the latest version of AdAware, and Microsoft's Malware removal tool. Also ran AVG.
    After restoring the computer (Vista Home) to a restore point a month earlier and before the latest Windows Security upgrades, there was some improvement after re-installing all of the available software from ACER, including the ePower Management. This improvement was NOT complete, and the computer would operate for a while then start acting up again. However, the ePower management software still appears to be corrupt. When you first reboot, the battery power-level indicator will show a fully charged battery, until you hover your mouse over it. Then, the computer seems to lose contact with the battery... showing no battery present. I un-installed ePower Management and the computer seemed to work on my account although it still did not detect a battery. It does not seem to work on my daughter's account (both administrator accounts). FWIW, the battery seems to be functional although not nearly like a new battery... maybe has 30 minutes charge left.
    The CPU activity seems to be related to the ability to detect the battery, and battery charge. I believe it is caught in some loop recognizing the battery, but then not recognizing it.
I contacted Acer about the problem and their solution was to buy a new battery since the computer was not longer under warranty and they really didn't know what was going on! In talking with friends, and checking on-line, the consensus is that laptop batteries don't last more than two years. You can keep them charged, let them run down, recharge them frequently: they still will only last about two years.
I just find it hard to believe that Acer has never heard of this problem, especially when I'm reading similar posts on this site.
Anyway, as deviant00 suggested, I got a new battery on Amazon.com for $56. They offered $30 off if I signed up for their credit card. The final cost was $26. The battery came today and the computer works like a charm. I also followed jell587's advice and scanned the computer with the Malware he suggested:no viruses.
The solution for me was buy another battery; expect it to last for a couple of years.
Thanks for all the help.
Posted on Mar 06, 2009
My problem was caused by a faulty battery. Disabling the battery in the windows device manager (thus disabling acpi communications with the device) immediately solves the issue.
Replacing the battery also solves the problem.
Posted on Mar 04, 2009
  • 447 Answers
First thing I would do is download Malware Bytes and run a scan and clean on the system just to make sure the performance problems aren't due to an infection of some sort. Post your results back here.
Posted on Feb 20, 2009
  • John Elliott
    John Elliott Mar 04, 2009
    Based on some of the other posts here I did some searching for any defect that may have been reported regarding the batteries in your model - didn't find anything that would prove it one way or the other. If the machine is clean of malware it obviously shouldn't be taxing the cpu that much.
    You may want to check on any updates for your model in regard to the power saving/ACPI.
Acer Aspire One Notebook model A0532H battery wont fully charge
Fully charge battery and if not 100 percent replace.
Nov 23, 2012 | Acer Aspire One PC Notebook
Acer Aspire battery level suddenly drops 80 %
Have you seen inside a laptop battery, it's not just a battery. It also has control circuitry inside, could be that. Not usually repairble but you can do some makes of battery. See here:Circuit.
Personally I would buy a new battery.
Jan 27, 2012 | Computers & Internet
MyAcer Z5610 switches itself off Ive had it for a few months Have checked all hard ware and all checks out Ok diagnostics Check out fine too Have asked for help from acer but was told probably virus
Hi Friends,
this is a common problem with a simple reason. The copper cooling fins in front of the fans are clogged with dust. Use SpeedFan (download free at http://download.cnet.com/SpeedFan/3000-2094_4-10067444.html) to verify. I bet it suddenly shuts off when you run a cpu intensive program. If the cooling fins are clean you can run 100% cpu for as long as you want. At 25 degrees room temperature the cpu temp will be around 65 degrees C at max. This is also too high, but the cpu they use (Q8200) is a "hot" one and Acer did a very bad job in the cooling solution.
Anyway, when the cooling fins are blocked by dust, the temperature at 100% cpu goes in seconds north of 80 degrees C. And the CPU has a safety inbuild. I forgot the exact temperature, I think it was 90 degrees C. At that temperature the cpu kills windows and you have a black screen.
Sometimes you can not restart at once or you might land in the BIOS at restart, telling you that the cpu had overclocking problem. You can not force it: when it is too hot the cpu will not start!
There is only one help. You have to open the **** thing and take out the fans. Than you will see what I mean with clogged cooling fins. Clean them with vacuum cleaner and brush - clean the fans and put it back together. I did it right now again (have to do it every 6 - 12 months depending on how much dust you have around).
Download the SERVICE manual to see how to open it. its just the back panel of the casing, and the metal sheet cover and than you can take out the fans (carefull with the connector - its small and can easily be broken). To take off the rear plastic cover (the very first step in the service manual) is tricky. Do exactly as described in the manual. when you push it down, it will bend a little and the hooks on the back will slide out off their anker holes.
link for service manual : http://www.google.com.hk/url?sa=t&rct=j&q=acer+z5610+service+manual&source=web&cd=5&ved=0CEEQFjAE&url=http%3A%2F%2Fzremcom.ru%2Finstructions%2Fmanual-acer%3Fdownload%3D254%3Aacer-aspire-z5600-z5610%26start%3D100&ei=aco3T_3FA8-SiAeFzKj6AQ&usg=AFQjCNHOiuAEA5Y0-9mLYvJyUTCy1HW0MA
Jan 13, 2011 | Acer Aspire Z5600 PC Desktop
Acer z5610 suddenly turns OFF Temperature is normal, no overheat, new thermal grease System scanned for errors, viruses - nothing WHAT DOES IT MEAN?
Are you sure the temperatures are ok? When I run DIVX Plus Converter on the Z5610 the CPU (intel Q8200) is running (naturally) at a high load. Speed Fan 4.42 shows rising temperatures going north of 90 degrees C. If only DIVX Converter runs the temperatures of the CPU cores is around 92 to 94 degrees C. But if I start browsing the internet the temperatures go close to 100 degrees C. When one of the cores reaches 100 degrees C Speed Fan shows MINUS temperatures on the cores (-10 to - 20 deg C). Speed Fan is just monitoring as it can not even detect the Fan.
When that happens the Fan stops completely!! And short after that the computer switches of (same as if you would pull the plug).
Obviously there is a bug in the BIOS or the Motherboard which leads to interpretion of temperatures above 100 degrees C as MINUS temperatures which leads to the stop of the fan.
I am sure that also happens whenever you use a CPU intensive program (like a game or any other video converter/rendering program). You might download a temerature monitoring program (i.e. Speed Fan - its free) and see for yourself. Also listen whether the fan stops working compltely (goes completely silent) when the PC overheats and short before it switches off. Let's see what ACER says to that.
I used to like ACER. But first Aspire 4310 tripping frequently because the VGA chip overheats and now that stupid fault ==> never ever ACER again. I will use the Z5610 for internet surfing and get a real all-in-one which you can use. That is a clear sign for me that ACER does not test their machines at all under full load - or knowingly sells faulty machines.
Dec 16, 2010 | Computers & Internet
The discharge of the battery do not occur normally. It is observed that while discharging it suddenly drops from 90% to 4%.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Dec 14, 2010 | Acer Aspire One PC Notebook
We have an Acer Aspire 5810TZ. It will not run unless the AC is plugged in. It shows 95% battery but not charging.
Um, no... I am seeing the exact same issue and my battery is not dead. System says it is 100% charged and the system was just running on battery for 2 hours the previous day now suddenly mine will not run on battery at all. I am starting to smell a product defect issue here but can't get anyone to talk to me about it at that level.
Acer Aspire 5810TZ-4657 Laptop
Oct 19, 2010 | Acer Aspire One PC Notebook
My Acer Laptop is about 3 yrs old and since the last month the battery has been running down within half an hour while in the past it used to last at least for three hours.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 25, 2010 | Acer Computers & Internet
Ummm, hi. i was wondering how many watt my Acer Aspire 5600 runs?
Power
subsystem
ACPI 2.0 CPU power management standard: supports
Standby and Hibernation power-saving modes
71 W 8-cell or 44.4 W 6-cell Li-ion battery pack
Acer QuicCharge™ technology
(for Aspire 5600 Series):
• 80% charge in 1 hour
• 2-hour rapid charge system-off
• 2.5-hour charge-in-use
90/65 W AC adapter
Oct 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
In task manger the cpu is constantly running between 90 and 100% on my acer aspire 1640z
check what applications are running and processes. you may find that programs are running on startup that are uneccessary and a simple tweek in the control panel or the programs themselves can make all the differance.
Sep 26, 2009 | Acer Computers & Internet
High CPU beginning after startup
I suggest not to use high end Softwares like games, ETC
Jun 14, 2008 | Acer Computers & Internet
Acer Aspire 3050-1733 Notebook Logo
902 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
