Question about Epson LQ-590 Matrix Printer
Printer is a Canon MP470 all-in-one, USB connected. OS is Windows XP. Latest printer drivers are installed. After print job completes, status of print job remains in print spool as "printing". If I cancel the job, the status becomes "deleting", but it takes about 3 minutes to actually delete from the queue. No other jobs will print while all this is going on. Cannot start and stop the spooler while this is going on either. This happens with every print job. It is not an intermittent problem. Any suggestions? Thanks - al
  • amghio Feb 19, 2009
    This is not a network environment. The printer is connected directly to the PC via USB.
  • 39 Answers
Is your printer hooked up to your network?
Make sure all your settings are correct and try connecting the printer directly into your computer. Then print if it does not work still then comment back and I will be glad to help.
Hope this helped.
-Please rate if this helped
Posted on Feb 19, 2009
  • Ryan Wendell Feb 19, 2009
    Alright well try disconnecting the printer from your computer and plugging it back in. Listen if the computer even recognizes it. Did this printer work before? Also maybe you need to re-install the software or update the drivers.
    Try that and let me know. I am always glad to help.
    Hope this helped.
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hi I have a Windows 7 (64 Bit) laptop and im
Please check the driver weather its support Win 7 64-bit or not, because Win7 have 2 varians 32-bit and 64-bit. If its not support 64-bit windows, you can download new driver but must be compatible with 64-bit system. Even if its the latest version of driver, but not support 64-bit system it won't be work.
You can download driver from here :
or here : (choose Windows 7 64-bit).
Uninstall the driver from your PC then reinstall with the new driver.
Hope this help.
Mar 09, 2011 | Canon PIXMA All-In-One Photo Printer with...
I can,t getmy printer to print from the computer. I have try everything.
What OS are you using? Check that you have the correct (latest) driver for your printer available here: Select your OS and click Next. Uninstall the old driver and disconnect the data cable (for directly connected printers) before installing the driver. For those Windows OS versions that include the driver with the OS, if the driver isn't automatically, check Windows Update for new updates (check for Optional Updates).
Are you getting any error messages (flashing lights on the unit)? Paper jams or low ink could be the problem.
Since the printer is a USB printer, try a new USB cable or a different USB port on the computer. Try a direct connection if you use a print server or USB hub. Check that the USB ports are working with a known good device. (For Windows, check if the USB ports are active. They can be turned off for security or power savings. The first is under the Device Manager (also check the driver status for the USB itself); the second is part of the Advanced Settings from the Screen Saver.)
Are the print jobs going to the queue and staying there? What is the printer status? For Windows, see the Devices and Printers Control Panel (older versions of Windows gave Printers and Faxes, IIRC). Try clearing the print jobs. For Windows, you can force this to empty by stopping and restarting the print spooler. Use the Command Prompt (for Vista and Win7 right click and choose Run as Administrator) Start > All Programs > Accessories > Command Prompt.
Type "net stop spooler" at the first prompt without the quotes followed by enter. Type Y if you get a warning about stopping the Fax Service. On the next line, type "net start spooler" again without the quotes and then hit enter. When you get a third prompt, restart the computer. Then check your printer queue. (You could do only the first step and then restart; however, you will need to go for a coffee break after the restart.)
Once the queue is empty, try a new print job. Next try resetting the printer. Unplug the printer (from both the computer and the outlet) and remove the data cable (from both the computer and the printer). Wait a short while and then reconnect everything. Try printing again.
Try printing a different type of file from another program. For example, PDFs sometimes won't print from Adobe Reader. This could result from a damaged PDF, a problem with Adobe Reader or something else. You can try using the Advanced Printer Properties (click the box when you select which printer you want to print to) and try printing the document as an image. Also try printing the same document from another computer/printer (transfer it to external media if you use another computer to minimize additional file transfer damage).
I hope this helps.
(BTW if you use a Mac, do not delete jobs from the Print Queue. Instead press Cancel at the printer. Otherwise, your computer may lose the connection to the printer.)
Nov 22, 2010 | HP Officejet 4315v All-In-One InkJet...
Will not load print driver this is the driver site for the canon mp470.
there select your windows OS then click submit to download a newer driver for your printer.
the driver on your disc may be no good for your windows or the disc may have a problem.
Hope this helps
Jan 03, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon mp470 not printing tried to upload on mac book pro says it sees it but  nothing printing..when asked for a print driver to install printer it does not give me the option to choose canon mp...
Download the most recent driver for your printer from the Canon website and install it.
Choose the Drivers and Downloads tab, select your OS and the then download the correct version. That usually takes care of it.
Aug 29, 2009 | Canon PIXMA MP470 All-in-One Printer
Vista recognizes printer, but nothing happens after job queues
Turns out it was a bad USB 2.0 cable. Finally tried the most simple fix, last, and of course, that's what worked. Just had to replace the cable.
Dec 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Need installation software
Kevin download drivers and software to suit HERE - please rate
In case I stuffed the other link link
Dec 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Status Box Remains at 99%
Try uninstalling then re-installing the drivers. Also if you are using Windows Vista you may need to go to the printer manufacturers website and download Vista drivers if you are running XP drivers for the printer.
Nov 24, 2007 | IBM Lexmark Z715 InkJet Printer
Epson LQ-590 Matrix Printer Logo
107 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
