Question about Microsoft Internet Explorer 7
Internet explorer 7
When I open a web page with internet explorer 7 sometimes the web page comes up full screen size and sometimes half my screen size and I have to enlareg it manually to full screen size..Is there a way to fix it so all web pages open on my full screen size..This did not happen with exploere 6..I am running windows xp home edition...Thanks Noel
  • 77 Answers
Its is dependant alot on your browsing to if you resize and then close the next time you open Ie it will be resized
Posted on Feb 19, 2009
Why is my google page continuously rolling up to the top of the page whenever I open it ?
It almost sounds like a stuck key like your up arrow key is stuck. With that said I would also try a different web browser like Firefox or Google Chrome you can get them INSTALLED over at the link below:
Ninite Install or Update Multiple Apps at Once
Jul 01, 2014 | Facebook Social Network
How do I increae AOL home page screen size to full screen and have it open that size?.I have AOL sampler on a notebook. Thank you,,Chris
Hello lknylandc, Usually to set the opening size of the Internet Explorer once opened you drag the upper left corner of the page in the upper left corner of the screen , and the bottom right in the bottom right of your screen. once this is done you close Internet Explorer at the next opening it should normally open the size it had when you closed it
Hope this helped Pierre
Aug 03, 2011 | Computers & Internet
How do i empty cach.
spacer.gif spacer.gif spacer.gif spacer.gif A full browser cache can slow down your surfing experience. When the cache is full, the browser has to search for the oldest cache segment and delete it before writing the new segment. Since all browsers cache pages as they go, it's easy to see how a full cache can lead to problems. It's a good idea to get in the habit of emptying your cache on a regular basis, generally after you finish your web surfing for the day. To empty the cache in Microsoft's Internet Explorer, follow these steps:
Open Internet Explorer (you don't have to be online) and click on tools/internet options.
Under Temporary Internet Files, click on delete files.
ip.jpgClick ok to the prompt that comes up.
That's it!
Jul 15, 2011 | Microsoft Internet Explorer 7
When i try to open facebook said problem in loading page .but i can open other browser.
If you have older browsers like Internet Explorer 6 or 7 - they will quite often show errors while opening. You can try to upgrade to Internet Explorer 8 (for Windows XP) or Internet Explorer 9 (Windows Vista and Windows 7).
Opera browser strictly follow standards and sometimes doesn't support non-standard web applications.
Therefore I would recommend to use either Google Chrome or Firefox 4 as your default browser. As for the above mentioned browsers - Opera and Internet Explorer there are no easy solutions for now.
Mar 07, 2011 | Facebook Social Network
When I open Internet explorer or any web sites on IE they appear
TIPS:
The default behavior for IE is to open at the same size it was at the last time it was closed.
While the default does apply in many cases it's not always consistent.
Try the following workaround.
Open a single IE window to the smaller size.
Drag the corners of the window until it completely fills the screen.
Do not use the maximize button to enlarge the window.
Hold down the Ctrl key, keep it depressed,
and using the mouse click File and then Exit on the menu bar.
Do not use the "X" in the upper right corner to close the window.
Internet Explorer should now open in a full window.
If it still opens to a smaller size repeat the above instructions, substituting the "Shift" key for the "Ctrl" key.
Jul 11, 2010 | Microsoft Internet Explorer 7
Running script error
Method 1: Disable script debugging loadTOCNode(3, 'whattotry'); If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
To turn off notification about every script error in Internet Explorer 7, follow these steps:
  2. On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
Method 2: Test a Web page from another user account, another browser, and another computer loadTOCNode(3, 'whattotry'); Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written. You can probably ignore the error and disable script debugging as described in method 1.
If the script error does not occur when you view the Web page from another user account, browser, or computer, the problem may be caused by files or by settings on your computer. Go to method 3 to continue to troubleshoot. Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer loadTOCNode(3, 'whattotry'); Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. In the Internet Options dialog box, click the Security tab.
  4. Click Default Level.
  5. Click OK.
Note ActiveX controls and Java programs are turned off at the High security level in Internet Explorer.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to Method 4. Method 4: Remove all the temporary Internet-related files loadTOCNode(3, 'whattotry'); Every time that you open a browser to view a Web page, your computer stores a local copy of that Web page in a temporary file. If the size of the temporary Internet files folder becomes too large, some display problems may occur when you open Web pages. Periodically clearing the folder might help resolve the issue.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 6, follow these steps:
  3. Click the General tab.
  4. Under Temporary Internet files, click Settings.
  5. Click Delete Files, and then click OK.
  6. Click Delete Cookies, and then click OK.
  7. Under History, click Clear History, and then click Yes.
  8. Click OK.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 7, follow these steps:
  4. Under Browsing History, click Delete, and when you are prompted, click Yes to confirm.
  5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and when you are prompted, click Yes to confirm.
  6. Under Cookies, click Delete Cookies, and when you are prompted, click Yes to confirm.
  7. Under History, click Delete History, and when you are prompted, click Yes to confirm.
  8. Click Close, and then click OK to close the Internet Options dialog box.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to method 5. Method 5: Install the latest service pack and software updates for Internet Explorer 6 or Internet Explorer 7 loadTOCNode(3, 'whattotry'); If you do not have the latest service pack or software upgrades for Internet Explorer 6 or 7, download and install them. They may contain updates that can help resolve the issue.
Jul 06, 2010 | Computers & Internet
Slow new page internet explorer
Do a google search for "google chrome"
If that runs slow you know its the PC, if it runs fine then you know its Internet explorer.
I no longer use internet explorer because it it so slow but i remember there was a setting which would scan web-pages for phishing threats.
Im not sure if its called that or if they have changed over to the smartscreen filter.
More info on smart screen filter here:
Microsoft smart screen
There are also some helpful tips here which could improve internet explorer perfomance:
Hints & Tips for internet explorer
I hope this helps
Regards
Mike
Mar 21, 2010 | Microsoft Internet Explorer 7
Web pages are mimimized when I first connect to them.
One common complaint is that IE will not open a spawned window maximised. This is not a feature in IE. You can TRAIN IE to open a larger size and you can set IE to start full size. But to tell IE to launch all IE occurances to full screen is not supported.
To change IE to start full size, right click on the IE icon/shortcut and change the entry "Run" to "Maximized."
Jan 10, 2010 | Microsoft Internet Explorer 8
Display on Internet expolrer 7
Use mozilla firefox.
Uninstall IE7, it sucks...
Feb 19, 2009 | Microsoft Internet Explorer 7
Internet explorer 7 & other web pages open in the minimized
The next time you open your browser drag the corners until it's maximized.
Close it by clicking "File"....then...."Close" instead of closing the window with "X".
From then on it should open to its' maximum size.
I'm a Windows user but a very strong advocate of the Firefox browser.
Good luck 1alf2.
Nov 18, 2008 | Dell Dimension 2400 PC Desktop
Microsoft Internet Explorer 7 Logo
300 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
