Question about Proscan 26LB30QD 26 in. LCD HDTV
Image Quality Is Very Poor
I Leave The LCDTV on All The Time And For Some Reason Its Showing Me Poor Quality Image. It Wasn't Doing That Before. I Tried To Reset The Settings on The LCDTV And No Change. Disconnected Everything Except The CableTV So I Can See The Image Change And Still No Change After Trying To Fix It. Solution Please
Yes I Solved My Problem... The Problem Was I Wasted Time on Here And So I Sent It Back And Got It Fixed After A Long Wait And Argument With Customer Support... And Sorry I Don't Want To Register For Professional Assistance... Would Probably Tell Me To Send It In To Get It Fixed... But Thank You
Posted on Feb 23, 2009
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
I hve a nikon coolpix 10 MP but the image quality is poor....i have tried resetting all the camera settings to default and dont know what else to do....also, it keeps showing a red colored icon (it...
The red clock indicates that the date and time need to be set.
As for the "poor" quality, there are many possibilities. If the colors are wrong, the most likely culprit is an improper white balance setting. If the pictures are blurry, that could be caused by subject motion, camera motion, improper focus, or a combination of the three. If pictures taken with the flash are too light or too dark, that could be because the subject is outside of the flash's range. Without knowing what you mean by "poor" I can't give you anything more than some ideas.
Dec 27, 2011 | Nikon COOLPIX S220 Digital Camera
My cmaera is working but ... image quality is very poor
hi
there are a couple of things that might be a reason
dust on the camera try cleaning it
then again there are some image quality settings that may have been set to a lower quality
also there are white balance settings that may have to be set properly
hope this helped
cheers
pls rate the solution
Jun 28, 2009 | Nokia N73 Cellular Phone
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Problems with sony cyber-shot dsc-t20
Kindly initialize your camera from menu and camera will starts with factory default settings.
May 27, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Mar 05, 2008 | Logitech QuickCam Communicate STX Personal...
Webcam
Feb 28, 2008 | Logitech Webcam
My webcam has all of the sudden started running slow on msn, it didn't before, so I don't understand why it is now, I've installed 3 different cams and it's doing the same with each one
Feb 27, 2008 | Logitech Webcam
Pic quality
Connection Issues:
Low Light Boost:
Using Latest Software:
Finally, make sure you are using the latest release of Logitech camera software. You can download the latest release from the Logitech Downloads + Parts page.
Feb 26, 2008 | Logitech Webcam
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Proscan 26LB30QD 26 in. LCD HDTV Logo
69 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
