I wasnt able to start my vehicle so i had my friend jump start, and then after a few minutes of driving it died again. so i bought and installed a new alternator. after starting my vehicle it was only able to idle a few minutes.
Have a load test done on the battery as it sounds like the battery is failing and the extra load from the lights is taking the power from the ignition system and so the coils fall below operating voltage and so no spark. Also alternators need some voltage from the battery to start charging and if there is insufficient voltage from the battery it won't work
SOURCE: Toyota Celica gt motor stalling out
Did you clean the fuel injectors? these always happen when they are blocked.
SOURCE: 1999 toyota tacoma Sr5 won't start
Check for fuel pressure when starting. Fuel pumps have a check valve in them that keep fuel in the rail at the injectors. If the check valve fails, the pump has to pump fuel all of the way up to the engine. Same thing with hot no-restarts. Fuel pump.
SOURCE: 1996 Camry 100 km stalling
This sounds like a common Camry problem. After driving my vehicle for about 20 minutes in highway traffic, the vehicle has difficulty idling when I slow down behind another car or turn a corner. This quickly deteriorates and then the car actually stalls when I slow right down or
Then usually the car starts again right away, but when I slow down again, stalls. Then when I start it up again, usually in traffic, I can’t get the shift into Drive. If I allow it to sit engine off for 3 – 5 minutes, it starts again, the shift can slide into shift, and the car goess off again, like nothing happened.
SOURCE: 87 Supra idles rough and dies out
I would suspect a vacuum leak. At idle under high vacuum the air fuel mix is being leaned out until you have misfiring so bad the engine quits. The exhaust smells rich because even a lean mixture, if it doesn't light off, if full of unburned fuel. At road speeds, the vacuum is low so the engine doesn't care if there is a small leak somewhere. It is getting most of its air through the open throttle. Check all your vacuum lines but remember that even if every line is okay, it could still be leaking from an old cracked intake manifold gasket.
SOURCE: 94 yota pickup starts and idles breifly then dies
If it's not your fuel filter plugged , or fuel pump malfunction, then it is probably your Mass air flow sensor, or your coil pack etc. You'll have to see if you have spark or fuel first. One of them is missing.
