Question about Frigidaire GLRS263ZD Side by Side Refrigerator
Side by side refrigerator freezer side working other side isnt
Our lights went out and we came home and found the freezer side cold and the other side hot. Someone said the fan motor in the freezer so we bought another one and installed it but the fan isnt turning. Any suggestions?
  • 77 Answers
Check defrost timer and manuly turn and see if it works!!!!!!!!!!!!!!!!!!!!!!
Posted on Feb 19, 2009
Freezer cold fridge isnt
freezer working,fridge not working,condenser fan ok, compressor running very hot.
Dec 14, 2011 | Whirlpool GS6NBEXR Side by Side...
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
First my refrigerator side stopped getting cold ,now my freezer isnt working the best , also theres frost in my freezer
you found frost in the freezer on the back wall . this caused no air flow through the coil. what has hapened is / the defrost system has failed . and the ref side gets to warm and next the ice cream will melt . look for bad heater or defrost terminator . and the defrost timer . . most compn problem .. mm
Jul 04, 2010 | Whirlpool ED2FHSS Side by Side...
My GE side by side refrigerator isn't working right. The freezer works great, but I can't get any coldness on the refrigerator side. Even at the highest cold setting.
Check your air door at the top left rear of your refrigerator side. If no air is flowing try opening it by hand while you are there. Also check the freezer for a fan sound to be sure your fan isnt stuck or dead.
Mar 14, 2010 | GE GSL22JFPBS Side by Side Refrigerator
Refrigerator-lights on not cold
If has a electronil controlboard i would say it is faulty.Cheak on warranty.
May 11, 2009 | GE PSC23NGS Side by Side Refrigerator
MY refrigerator is running but is not getting cold.
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Oct 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
Our freezer works fine ....but our frige isnt ..help!!!!!!!!!!
Your automatic defrost system is not working. There is a timer which controls the defrost by turning on the heaters for 18-22 minutes inside the back wall of the freezer section. after the defrost time it returns the system to cooling.
You have one of three items faulty. The timer, the heater or the defrost terminator switch.
Jul 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Nov 07, 2007 | Whirlpool GD5SHAX Side by Side...
Frigidaire GLRS263ZD Side by Side Refrigerator Logo
51 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
