Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint - Drainig Issue
My hotpoint - when draining - sends water into the overflow and onto my countertop/sink.
PLEASE HELP.
  • 547 Answers
If you have a garberater you need to remove the drain pipe and clean out
Posted on Feb 19, 2009
Hotpoint Built-In Dishwasher HDA3600DWWmy dish
there is an electronic solenoid near where the drainhose connects to the sump that changes the waterflow direction from recirculate(washing), to evacuate (draining). this is electronically controlled by the timer. you can test the power leads at the solenoid for voltage when it sould be draining. if none then the timer is faulty. if there is voltage then the solenoid is faulty. if the solenoid is engageing, then the water diverter is faulty. if the water diverter is broken, replace the dishwasher.
overflowing is another problem of its own. the water level float/ sensor is not working and could be caked with detergent. work the float from the inside of the dishwasher, it should move freely. if so, then there is a switch connected to the float on the underside. test it with an ohmmeter. if bad replace it. if it is an electronically timed water level control then it could be a problem with the timer as well, but with hotpoint they are usually manual.
Sep 27, 2013 | Hotpoint Dishwashers
Dishwasher wont drain
If you will open the door on the front of the dishwasher, you should see two small screws going through tabs holding the dishwasher to the countertop. They are in the front, and above the door.
If you will remove those screws, you should be able to pull the dishwasher out about halfway into the room.
Do not pull it farther, because there are 3 important components you want to leave hooked up. The electric wires, the drain hose, and the fill hose.
Remove the front lower panel that hides the bottom of the dishwasher, and you should see a water pump made of plastic maybe the size of your fist, maybe on the right side.
The drain hose should be attached to that pump, as should electric wires. The drain hose goes to the sink drain in most cases
Find a way to catch the water and or sludge that may come out of that hose, and remove the hose from the pump that goes to the sink drain. You may need a pan that holds a quart or more liquid.
See if that hose is clear of being plugged up.
Sometimes too much food left on the dishes can plug up the pump or the hose. Examine the pump to see if it is plugged.
If the hose goes to the garbage disposal, perhaps that is where the plug-up is.
Jan 07, 2013 | Hotpoint Dishwashers
Hello, I have a Hotpoint R134a fridge freezer which has been leaking out of the bottom. THis is serious as it's leaking onto a wood floor and I want to get it taken care of or I'll have to replace...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 04, 2011 | Hotpoint FFA90 Bottom Freezer Refrigerator
I installed the sink drain with overflow and water is leaking from behind the sink and under the countertop. What did I do wrong.
a vessel I dont beleive has a overflow. you need a differant waste for that unless theres something your not telling me
Sep 03, 2011 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Hi i have an hotpoint ultima its 2years old, it was working fine untill the council fitted new kitchens. then it started not draining right then when it was draining water was comming up the sink now no...
Sounds to me like therte is a problem with the draining of the washer due to the way it
is connected to your sink waste.
Get that sorted, and you will probably find that the other problem will disappear.
Jan 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
I have an Hotpoint Aquarius washer dryer WD61.I moved my machine from one house to another in the car but led it on its side.After it was re-installed the washer worked fine until it come to pump the water...
take bottom panel off at back. there is a large diameter hose going from the bottom of the tub to the pump. disconnect this hose at the tub end and you will find the filter inside (carefull, water may come out)
also, put onto drain program and check the pump is actually turning
also
if drain is connected to a spigot on the sink trap, this spigot may be blanked off if iot has never been used
Oct 14, 2008 | Hotpoint Washing Machines
Hotpoint ultima 1200
Kirsty - There could be an item like a hair clip Jamming the pump impeller. Or then it can be only a blockage in the filter or in the waste pipe or if the waste is connected to your sink drain check that the blockage is not there - either in the end of the pipe or in the sink connection.
Try disconnecting at the sink, holding the waste pipe into a bucket see if it will pump out then. If it does then the problem lies in the sink plumbing - if not then it lies in the machine.
If the pump and filter and hoses are definitely clear you could have a Pump, PCB or wiring fault. Hope this helps.
Mar 12, 2008 | Washing Machines
Hotpoint Ultima dishwasher DF32
you are probably plumbed in under the sink for the drain hose. a common problem is water coming back down the drain hose when you empty the sink. if so take the drain hose up as far as possible in a swan neck. other possibility is a leaking fill valve
Jan 26, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
126 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
