Question about Toshiba Satellite Pro A200-EZ2204X Notebook
Error code 3102ED-14-00000000
I have a problem when trying to make copies of discs through my Toshiba disc creator. I have a Toshiba sattelite A200-AH7 laptop. When trying to copy cd or dvd disc the following message appears: Error code 3102ED-14-00000000. Can you provide me with any information about what this code means and how I can fix this problem. I appreciate any help.
The problem may occur when a temprary file "TempFile.tdi" already existed.
Try once more after removing the file or changing temporary folder.
Ichiro from Japan
I'm not concerned with Toshiba. :-)
Posted on May 17, 2009
Hi, I have a problem with my toshiba, I have tryed to burn a disc but the laptop does not let me do it, and shows me a error 3109A0-34- 0000000 please helpme what do i can do for fix the problem?
It seems that you are using Toshiba Disc Creator.
The error means that the data that you want to burn on the disc is larger than the capacity of the disc (either CD or DVD) try to reduce the number of items you are trying to burn, and if you are trying to burn an ISO image then it is larger than the disc you have in the drive
Sep 03, 2011 | Computers & Internet
I need Toshiba Satellite L455D-S5976 (PSLY5U00Q01T) PC Notebook factory restore instruction
Hello there,
Newer Toshiba laptops usually have the ability to create recovery discs that will let you recover to "factory settings." Try this:
1. Click Start
2. Select All Programs
3. Select Recovery Disc Creator.
Recovery Disk Creator
4. Within the Recovery Disc Creator select Create
5. When prompted enter the first blank DVD and select Ok
6. When prompted enter the second blank DVD and select Ok
I hope this helps. Thumbs up if you think so.
May 04, 2011 | Toshiba Satellite L455D-S5976 Notebook
I am trying to copy Windows 7 SP1 either as the simple service pack or Windows 7 Ultimate with SP1 but for both files I receive the same Toshiba Disc Creator error message 310981-34-00000000. I have...
That will only work with the Toshiba Disk Creator software and if anyone has made those already it won't work at all. Those are both copy protested files that use a special format to keep people from making copies of them. The back up files stored on the hard drive for restore purposes only work with the disk creator software that comes with Toshiba computers and that software has a hard coded counter that won't let you make more than 1 copy. If your using the correct software and still have the problem it maybe the DVD's your using. Make sure you have DVD's that are a compatible format with your DVD writer function. You may need the DVD -R instead of the +R dvd's you indicated you are using.
Feb 18, 2011 | Computers & Internet
TOSHIBA Disc Creator 2.1.0.2 give me Error Code: 380381-26-51037200 when I try to burn a DVD (Data Disc). I have a TOSHIBA Satellite PSL 40E laptop with Win 7 Ultimate. Can you help me to solve the...
Have you tried using another software ? One like
http://www.softpedia.com/get/CD-DVD-Tools/Data-CD-DVD-Burning/Ashampoo-Burning-Studio-Free.shtml
Nov 11, 2010 | Computers & Internet
Toshiba Recovery Disc Creator isn't working
hello lazerr_man,
Try to use another freeware burnprogram like burnatonce to create an
other CD, just to check if the Combo-drive is writing properly.
If you don't get any error messages like the ones from Toshiba program, then the problem is the toshiba software.
If other burn programs find difficulties in accessing CDs or DVD-Rs
then the drive itself giving you a hard time and might seek for replacement.
You may find the toshiba exchange parts too expensive and the internal drive is still reading disks properly, then think about an external dvd-rw drive, but make sure to buy a highspeed USB one (or even firewire, if the laptop has the port), else it will run rather slowly.
good luck
Sep 07, 2009 | Computers & Internet
Error code 03-eeee-0000 when i try to use restore disc on my toshiba sattelite laptop
error code 03-eeee-0000 when i try to use restore disc on my toshiba sattelite laptop
Jul 17, 2009 | Toshiba Satellite A215-S4747 Notebook
I AM TRYING TO BURN A DVD USING TOSHIBA DISC CREATOR, BUT THE COMPUTER KEEP SAYING THAT THERE IS AN ERROR CODE : 0600277-26-28031100. HOW CAN I FIXED THAT?
try to re-install the toshiba disc creator driver and try to burn the cd again. if it doesn't work i suspected your dvd rom drive is faulty. you need to replace it. call toshiba and request to replace the drive.
if machine is under warranty no need to pay for replacement.
Jun 30, 2009 | Toshiba Satellite P105-S9722 Notebook
Drive cannot rocognise disc info
Try doing a clean install of Creator 2009. Creator 2009 should not have anything with Sonic. You need to remove older software, if you don't, that will cause problems in the future.
Mar 30, 2009 | Roxio Creator 2009 for PC
Toshiba Satellite P200
Couldn't find that specific error code anywhere. However to give more information try this. Try to burn a CD, when you get the error code go to:
Control Panel>Administrative Tools>Event Viewer then Services and Applications. See if you get an "error" on a particular application you should as the event viewer documents everything that goes on in the system. Let me know what application or file is causing the error..standying by.
Mar 12, 2009 | Toshiba Satellite P305D-S8828 Notebook PC
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
362 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
