Question about Bosch Axxis WTA 3510 Electric Dryer
The dryer is heating up, but the clothes aren't drying
I think it's not spinning, I have a Bosch Assis WTA4400US
  • 547 Answers
You need to have belt replaced
Posted on Feb 19, 2009
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
Seems to heat. I know it's spinning. Why aren't my clothes getting dry?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 18, 2011 | LG DLE5977 Electric Dryer
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
Looking for a replacement belt for a bosch axxis wta4400us dryer there don't seem to be links or parts lists readily available. Where can I find one?
The Belt you need for this machine, is the same one needed for a Danby DCD5505W Dryer. You can find a replacement belt at Repair Clinic, belt #669956, and you can also look-up a supplier using the mfg belt number (8PH 1930). The belt, with shipping is about $20.00
May 04, 2011 | Bosch WTA4400US WTA 4400 US Axxis Vented...
Dryer is not heating to dry clothes
if its not heating at all, first check electrical and make sure your getting 220 to the dryer if you are more than likely its the heating elements, check them and replace if bad
Apr 26, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Clothes dryer stops spinning before clothes are dry
sounds like a bad cycling thermostat!
May 26, 2009 | Bosch Dryers
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Dryer doesn't dry clothes
With the dryer not connect to the external venting turn the dryer on and see if there is air coming out ot the vent from the dryer. Is this flow of air strong or weak?
If weak then there could be a problem inside the dryer some where. Perhaps the fan is not operating properly. Just my thoughts.
You say you have check the beginning and end of the duck vent pipe. How about seeing if it venting duct is clear from one end to the other.
Good luck
Jul 13, 2008 | Bosch Axxis WTA4400 Dryers
Bosch Axxis WTA 3510 Electric Dryer Logo
204 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
