Question about Exercise & Fitness
Proform treadmill 580si motor is not working
The treadmill got wet and when you turn it on it will go very fast for awhile and then slow down and then speed up. so i installed a new motor control board and now the motor does not come on. can you help
  • Anonymous Mar 20, 2014
    just added new motor control board to equipment. now it shuts off ~ 3.5 RPM w/ERR 7 on control panel.
  • 1,902 Answers
Recheck your wiring and check your ground. If all that checks out then triple check your control board. Also the motor SHOULD have a reset button make sure that the button is not out and it is fully pushed in
Posted on Feb 19, 2009
When on treadmill there is a "studder"
Check if the running belt is lubricated. You can't run an engine without oil. So, spray a good quality silicone lubricant on the base of the running belt. It is best if you spray on a lint free cloth just enough to make a wet patch. Do it outside so that no spray residue lands on the floor and becomes slippery or lands on the carpet and stains it, then return inside and lift the treadmill running belt and soak or smear the base with the wet patch of the cloth and run for a full minute. Then lift the belt again and give it another swipe on the entire base, then feel the base with your fingers or hand to see if it feels wet and smooth. Run the treadmill for another minute at slow speed, otherwise the liquid can fly and splatter on wall or floor. If it still hasn't solved the problem, then it must be the motor brushes, or it may be set to run slow and fast according to the running settings on the console. Mine does the same thing if it is programmed to do 1 minute slow and one minute a bit faster. Good luck.
Jul 30, 2014 | Proform Crosswalk 395 Treadmill
580si speeds up too high after reset
1) You must RUN Inmediately the software calibration for easy diagnose and troubleshooting and fix it.
God bless you
Jun 26, 2012 | Proform CrossTrainer Treadmill
My proform 3.8 treadmill isn't running at the
see the diagram attached adjust the speed sensor, clean, and tight the connector very well.
2) Run after you did the adjustment the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 01, 2012 | Proform Exercise & Fitness
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
I have a proform 740CS, it sometimes slows way down, if I step off it will sometimes speed up much faster than what it's set at, but then slows down again when I step back on. Other times, it remains...
Please LUBE very well the Walking Belt.
2) Inspect the drive belt motor, if is loose, Retight.
3) See if there loose wires for MOTOR.and retight.
4) The walking belt LIFT wiht your finger must be 2-3"
otherwise Readjust with the allen screw rear.
How To Lubricate Treadmill
Nov 22, 2017 | Proform 7.0 Crosstrainer Treadmill
My Proform XP 650e Treadmill starts and suddenly stops. The belt turns real fast then it suddenly shuts down like the power was turned off.
This condition is when the treadmill goes to full speed as soon as you power up the treadmill. Typically when this occurs, it is an indication of a short circuit in the motor controller.
Jun 28, 2010 | Proform XP Weight Loss 620 Treadmill
Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
May 02, 2010 | Exercise & Fitness
Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor.
Aug 10, 2009 | Proform Sport 1000 Folding Treadmill...
Belt needs tensioning up on its adjusters or the motor drive gear has come loose and needs tightening back up.
Jul 31, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
1,173 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
