Question about Intel D845GVSR Motherboard
Emachine T2890 won't power up. After reading some posts on this issue I went ahead and replaced the power supply, but the unit still won't power up. I am fairly certain that the old ps was fried since jumpering out the green and black wires on the main plug did not turn on the fan. The fan does work on the new ps when jumpered. The motherboard shows no visible signs of being bad, no bulging capacitors or leaks. No signs of overheating. When the power supply is turned on a green LED lights up on the motherboard but when I try to turn it on I get nothing. I also tried unplugging everything from the mb except the power supply and 1 ram card. Is there any way to verify if the mb is bad or any other suggestions?
  • mdough_ids Mar 21, 2009
    I found the same thing, but don't have another computer to try it in. I did find some online notes that the PS has a known problem (that eMachines won't recognize) that apparently fries something, but I don't know if it is CPU or what?
    Notice that the switch on front will not ground the #PS_ON signal, but like the other guy, I can ground this pin, and the fan begins to run, and power is fed to the drive units, however the drive units don't respond either, and no beeps whatsoever. Is this CPU?
  • Richard Ray May 11, 2010
    hi ljcast419
    do you have another machine u can test the cpu in as it does sound rather like the cpu cud be a culprit...
    there are a number of factors why ur machine wont switch on..
    1. faulty ram......normally a sign is when you get peeps from the pc speaker
    2. cpu.....cud be dead
    3. motherboard.....cud be dead
  • 253 Answers
If you remove all the RAM fro the system and power it on, you should hear "Memory Error Beeps" if not, then it is usually Motherboard or CPU, for around $30.00 you can purchase a PCI POST code reader to try to pin the problem down further.
I am assuming from the post that all PCI cards (dial up modem especially) have been removed. Sounds like a bad MB or CPU, but if the video is integrated,( built on the motherboard, and not a seperate card, the memory is responsible for video also, and it maybe defective.
Posted on Mar 30, 2009
2 Suggested Answers
SOURCE: Emachine T2890 won't power up. New power supply.
move its bios jumpur on cofig mod and after some time post it its orignal post .it will ok ok Insha Allah
Posted on Feb 28, 2009
My emachine EL1352G-41W wont turn on?
Power supply is most likely your problem--many desktops with this issue have before it happens an issue where it has to be turned on several times and will finally come on and stay on.
The power supply in most cases is a unit that can be removed and tested (most shops charge little or nothing for this.)
If you are able to get it out look for bad filter caps on that board--some examples:
If puffy caps are found you have two choices---replace them all or if possible buy a generic power supply replacement............
Jun 11, 2012 | Computers & Internet
I trund on the playstation and then it went origeng then keeped on flashing red what do i do
Replace the power supply. This issue is known as YLOD (yellow light of death). Your power supply inside the unit has went out. You can pay Sony around $150.00 USD to repair it or you can open it yourself and match to a new power supply from E-Bay. They run about $40.00 on E-Bay and are very simple to install. Re-Post for more help!!
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
I have the Bravia 40" KDL 40V3000. When I turn the TV on the panel powers up then the TV goes to standby and I get 13 flashes from the standby light. Reading on one of your other posts, I went ahead and...
Power supply board is dead 90% of the times.When the power turn on LED power light indication flashes.5% might be the Tuner board,that the board taking in the incomming broscasting cable plug into this board.5% might have both death boards,power supply board and the Tuner board.Problems,u have never indication LCD inverter board,backlight problems.U shouldn't have replaced the LCD inverter backlight board,bacause backlight are dead,have flashes of picture few sec.than dies,still have hear sound.
Aug 05, 2010 | Sony BRAVIA KDL-40V3000 Television
Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply: my cpu fan is running but at a low speed. When i t...
In my opinion you have a faulty power supply, replacing only the fan may not solve your problem. Try replacing the power supply.
May 16, 2010 | E-Machines Emachine T5026 power supply **...
T2890 video card replacement power source?
The graphics card takes its own power from the motherboard.
May 28, 2009 | Intel D845GVSR Motherboard
Feb 19, 2009 | Intel D845GVSR Motherboard
2 year old E machine
Dear zmatt,
Looks like the power outlet or UPS may be at fault. Try a different outlet. That's all I can thik of.
Jul 29, 2008 | E-Machines eMachines Desktop PC
Intel D845GVSR Motherboard Logo
626 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
