Question about Dell Latitude C610 Notebook
Uninstall system mechanic 7 does not work
Internal error: cannot find ut compiled code record for unstaller.
  • 2,229 Answers
Go on the web (google) and search for "office installer cleanup"
Download and install it.
Run it from the Start>programs.
Be careful what you tell it to uninstall. Be sure you have the correct program checked.
Once you run it, restart the computer and the program will be gone.
You can then delete the associated files.
If this helps you, please rate the answer. Thanks.
Posted on Mar 17, 2009
How do I unstall kikat on my HTC one
Kitkat is the operating system. You do not want to uninstall it.
Oct 04, 2014 | Computers & Internet
I can't uninstall a software from my notebook with windows 7, 64bit. The error code is 1628.
download this http://www.techsupportforum.com/forums/external-link/?link=http%3A%2F%2Fcleanup.stevengould.org%2F and then try again :)
Feb 11, 2012 | Computers & Internet
How can i uninstall Blue Coat K9 Web Protection as i have forgot password
even if you forgot the passowrd you can unstall it without a single remains of that software,
for windows XP use winxp manager (  you need fto have microsoft dot net 2.0 or later pre intsalled in other to install winxp manager)
for windows vista use vista manager
for windows 7 use windows 7 manager
 all this software can be downloaded from www.yamicsoft.com
let me know if it's helpful to you
Dec 07, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron E1505 absolutely no sound anymore
1. remove all external peripherals.
2. use the internal speakers
3. uninstall / reinstall the audio drivers
4. reboot system
5. if still hearing the crackling sound check if cracking sound can be heard only inside windows of even in the bios.
6. check bios hdd if in acoustic mode performance if yes then set it to normal.
Oct 08, 2009 | Dell Inspiron E1505 Notebook
My built-in microphone is not working on my inspiron 1525. nothing is muted and when i look at the audio equipment installed there is nothing there. I tried to download the driver but it said there was an...
You can try the steps below and it should fix the problem.
A.Adjust the Audio Source Control Volume for the Microphone
1. Double-click the Volume icon in the system tray located in the bottom right side of the screen.
2. Click to uncheck any check marks in the boxes next to Mute to turn off muting for each volume control.
3. Click and drag each Volume Control slider to the top of the scale, if necessary.
4. Click Options and then click Properties.
5. Click to select the Recording radio button.
6. Click to check all the boxes listed under Show the following Volume controls:.
7. Verify the Mic Volume box is checked and click the OK button.
8. Click to uncheck the Mute box to turn off muting for the Mic Volume, if necessary.
9. Adjust the Mic Volume slider until it is near the top of the Volume Control scale.
10. Click Options and then click Exit to close the Volume Control window.
B. Test Sound Recording with the Dell Diagnostics
Follow the link below to run PSA
http://tinyurl.com/6f3lcd
1. Ensure the system is powered off.
2. Press and hold the Fn key while system is powered off and press the power button to power the system on.
3. Release both buttons in 5-10 seconds.
4. The PSA diagnostics sequence begins. Tests will be performed automatically.
5. A message will display “where the color bars displayed”. Press ‘Y’ to continue testing.
6. Make note of any alert tones or error messages and forward it to us.
7. When a prompt comes to run more memory tests, Press “NO”.
8. Another test starts and chooses option “TEST SYSTEM”.
9. Please select “CUSTOM TEST” from the options.
10. Please locate “Audio”, click on that, and find “quick test only” (right top corner). Start test, by clicking on the start test button.
11. Make note of any alert tones or error messages and forward it to us.
Download and Install the Latest Audio Driver
Uninstall the Audio Driver
1. Click Start and then click Control Panel.
3. In the Control Panel window, double-click the System icon.
4. If present, click the Hardware tab.
5. Click Device Manager.
6. Click the plus (+) sign next to the Sound, video and game controllers category.
7. Right-click the name of the driver you want to uninstall and then click Uninstall or Remove.
Download and Install the Most Current Audio Driver Available
1. Go to the below mentioned link.
http://tinyurl.com/3vlce4
2. Locate Audio and click (+) sign next to it.
3. Click the Audio driver that you want to select. You may have to specify an installation method or operating system type.
4. Click Download Now in the File Name section.
5. Click Save. Using the Save In: drop-down menu, select My Documents, then click Save.
6. Click Open when the download completes.
7. Click Continue.
8. Click OK.
9. Click Yes in the Folder does not exist. Do you want to create it? Window.
10. Click OK, and follow the onscreen instructions.
Test the Microphone Using Windows® Sound Recorder
Click Start, click Programs (or All Programs), click Accessories, click Multimedia (or Entertainment), and then click Sound Recorder.
Click Record, and speak into the microphone. You will see the green waveform react to your voice.
Click Stop.
To hear your recording, click the Play button and verify the volume level.
May 12, 2009 | Dell Inspiron 1525 Notebook
The Internal Mic In My Dell Inspiron 1525 Isnt Picking Up Sound??
You need to set the internal mic as the default input device. To check this Right click on the sound icon next to the time and select Recording properties. In the Recording properties right click on Arrey Microphone and select set as default. If this does not help. Uninstall and reinstall the sound drivers. To uninstall the sound drivers click on start and type DEVICE. Open device manager from the results and then look for sound devices. Click on the Plus sign next to Saound and audio devices. Right click on the SigmaTel entry there and select uninstall. Put a check on remove this driver from the computer. Once done restart the computer and go to support.dell.com and click on Drivers and Downloads. Enter your system service tag and download the Sigmatel audio drivers and install them. Check if the MIC works after the restart. If the Arrey microphone is set as the default and you have uninstalled and resinstalled the drivers and it does not work in MSN try recording with the Windows sound recorder and see if it works there. To open the sound recorder click on start and type SOUND. Open sound recorder from the results. Incase the mic does not record even in the recorder it could be bad or have a loose connection. If in warranty call/chat with the Dell technical support. If the warranty has expired consult a local computer guy.
Mar 29, 2009 | Dell Inspiron 1501 Notebook
I accidentally uninstalled sony image converter 2.
go to system restore it might have restore point from earlier date before you accidentally uninstall the program.
click START>>>>>All programs>>>Accesories>>>>>System Tools>>>>System Restore
Mar 13, 2009 | Sony VAIO VGN-CR305E/R Notebook
Cannot record sound
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu..
Dec 20, 2008 | Toshiba Satellite A215-S4697 Notebook PC
Sound and itunes
start install itunes again , it show options then click remove from that it will uninstall , till the problem is same use third party software to unistall i refer cc cleaner its free download first uninstall the itunes and restart the system then sound will works i think so
Mar 25, 2008 | Computers & Internet
Dell Latitude C610 Notebook Logo
911 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
