Question about Memorex MLTD2622 26 in. LCD TV
Memorex LCD TV stopped working, wont turn on
I have a Memorex MLTD2622 26" LCD TV w/ built in DVD player. A few days ago it stopped working. I was playing my Xbox 360 on it when all of a sudden the screen went black and the power light on the front flickered for a few seconds and then went out. After that it would not turn on. We tried power cycling, using different power outlets, and using another compatible power cable. Nothing worked, please help.
rduncan27
SOURCE: looking for wall mount for MLTD2622 26" tv
I had similiar issue with 32 inch...bracket required an adapter which I found through Best Buy. Check out Sanus.com They should give you discription of what you need and tell you where to get it. Adapter was very cheap ($19.00 or so). It is essentially two metal bars that bolt to regular wall mount, the bars will line up with bolt holes on TV.
Posted on Jan 26, 2009
  • 362 Answers
SOURCE: Can not access menu or input functions
Hi rduncan27,
I will be happy to help. 88% of LCD tv problems are with the backlight, the symptoms you described indicate a probable inverter malfunction. Lets do a simple test to check the functionality.
  1. Get the tv to a point that it is producing sound.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely for a dark video image.
Let me know your findings and we can proceed from there.
Lone99star
  • 14 Answers
SOURCE: TV automatically shuts of at 1hr.
replace D10 on power supply board near large capacitor (100uf 450V)
Posted on Jun 23, 2009
jhinsincity
  • 616 Answers
SOURCE: after few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at milleniumtvsvc@gmail.com
Posted on Jul 21, 2009
SOURCE: "No Signal" on Memorex 8" under the counter LCD TV/DVD
Solution..... The unit ONLY accepts digital TV input. Typical cable input is NOT digital. If you want to run cable into the TV, you must treat it as auxiliary input, meaning you have to connect it through a cable box, just like the input was from a VCR. You then control the TV channels from the cable box, not the TV itself.
You can typically sign up for digital cable for an extra fee, just like for any other HDTV.
I wish I could give you a better answer but this is the only way we got ours to work as we do not have HDTV service on our cable yet.
Posted on Jul 30, 2009
How to do an update on memorex lcd mlt 3222
If you mean a firmware update to the MLTD3222, there is no way for a user to update this TV with built-in DVD player. The manufacturer doesn't provide updates and has no way to access them from a DVD, USB flash drive or SD card. (The manual for the related MLTD2622 is available from Memorex support: http://support.memorex.com/app/answers/detail/a_id/939 . )
I wish that I had better news for you.
Jul 08, 2014 | Memorex MLT3221 32 in. LCD TV
Question
You might need to clean the lens. They have CDs that will help clean this.
Aug 28, 2012 | Memorex MVD2016 DVD Player
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Built-in DVD player in tv stopped reading discs
try to clean the laser lens with rubbing alcohol and a q-tip. be gentle
Sep 24, 2009 | Televison & Video
DVD player turns on; but apperently will NOT play the movie after we put it in... HELP!!!
I had the same issue and could have kicked myself in the ***! Make sure the AV slide switch is in the out position or it will not play at all. As soon as you switch from IN to OUT it will work properly.
May 02, 2009 | Memorex MVDP1088 Portable DVD Player with...
DVD player wont work with TV
First, make sure that the units are connected properly * I know it's obvious, but I did it myself one day * Then on your T.V. remote, try hitting INPUT and it should run on your VIDEO channel.
This will work 99.99% of the time. Let me know,
Thanks
Justin
Please rate me.
Jan 07, 2009 | Memorex MVD2042 DVD Player
Memorex 32'' LCD TV/DVD combo, DVD will not play
funny how **** happens....mine turns on and says memorex then stays on with no picture or sound.
Aug 10, 2008 | Televison & Video
Memorex dvd player model # mvd2042
I'm having an identical problem with my very new "Memorex DVD". After trouble shooting everything suggested in the manual, I'm on my way to buy another "new" dvd player. Definately will not be Memorex.
Jan 04, 2008 | Memorex MVD2042 DVD Player
Turns
When you say turns off do you meen power switches off or just stops playing.A good test is to play a cd,if this plays ok the problem is more than likely laser related and with the cost of replacing the laser being so expensive,it can be cheaper to replace player itself.Have you tried cleaning the lens assy with cleaning disc??
May 10, 2007 | Memorex MVD2022 DVD Player
Memorex MLTD2622 26 in. LCD TV Logo
443 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
