SOURCE: Tom Tom one just comes on and then says that there is no GPS devi
It "might" be that your tomtom has lost its position due to you moving countries. the TomTom stores its last position so each time you switch it off then on again it can find the satellites it had before quickly. Because you have moved a long way ( on the aeroplane ) the TomTom now thinks you are still in America so it's looking for the satelittes over America rather than over the UK.
I would try this :
if you dont get any bars at all then it's likely your tomtom has become faulty in the receiver or antenna section and will need proffesional repair . Rare but It is also possibly a files / data fault on your SD card . In this case if you made a backup of the card , you will need to revert to that and reinstall the files to the SD card.
GOOD LUCK
SOURCE: alarm for speed cameras or red light camers on my tom tom one
1 Change Preference
2 Warn When Near POI
3 Choose Your Red Light Camera POI
4. Set how many yards from it you want to be warned.
5.Choose Sound
Done
Good Luck
SOURCE: I need to reset the time on my Tom Tom XL330S
Tap "Set clock" button to select the type of clock that is shown and set the time.
SOURCE: TOM TOM GPS Updates
That depends on where you got it and if the documentation for the updates was in the box.
Usually the answer is yes.
Those from Tiger Direct do.
I have used it before now with few problems.
Couple of times I have had to talk to them but they have always been good and given me a code or new code to get the updates.
SOURCE: i forgot my passwordo to enter my device GPS tom
Reset it via button at rear, in a small hole...use a straightened paper clip. Then you must re-setup all again.
