Question about Braun Tassimo Espresso Machine/Coffee Maker
Standby light is flashing
We unplugged a tassimo working coffee maker and then a few hours later plugged it in and now we just get a flashing standby light. When we put in a new disk, the yellow heating light and the standby light flash. if you leave it going long enough, all the lights flash. Tried to unplug, refill, reseat water container, clean the piercing device, barcode reader, still nothing. It worked FINE until it was unplugged. Any suggestions?
  • Anonymous Mar 16, 2014
    b-40 add water and heat light flashing, wont do anything unless i unplug it and wait a minute and plug back in
  • Anonymous Mar 28, 2014
    All lights flash unit will not start fith full tank of water. Short heat up herd, Bar code reader cleaned.
I had the same problem with my machine and managed to get it working again in a few easy steps. This machine is great but it can be VERY tempermental so here are a few tips:
1.The barcode reader MUST be clean or it will not read what the disc is (It is the little glass screen where you place the disk.) If it is not clean the lights will all flash.
2. The little floaty thing in the water container has to be floating in order to keep the machine running- if it won't float, shake it well to dislodge the air pocket that might be jambing it.
3. If the red stanby light won't go away, it is because the disc you are using is either damaged or leaking and it WON'T go away until you replace the disc...(you might have to do it more then once) if that doesn't work- try hitting the reset button on the back of the machine (the little black switch that has a (- and o) as well as unplugging and plugging the machine back in. Lastly, what worked for me was inserting a new disk and only partially clicking in the disk so the 'heating' light came on- leave it like that for about 10 seconds and then very slowly close the disc completely. Hope this helped!
Posted on Feb 25, 2009
Why all the lights from Braun tassimo coffee machine flash?
The float that detects the water level might need freeing up.
Or, assuming detachable water container, ensure that it is seated fully. Lift it up a bit and guide it down firmly.
If it's not that, try unplugging the machine for about 5 mins. and see if it resets to normal operation.
Jan 31, 2015 | Braun Tassimo Espresso Machine/Coffee...
Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it
Bosch Tassimo T65 Repair Questions,... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > Bosch > TASSIMO
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it · Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/red_light_water.../tassimo
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Bosch TASSIMO cleaning condensation tray Unsolved ...
www.fixya.com/unsolved_problems/...condensation_tray/.../tassimo
Aug 23, 2014 | Bosch Tassimo T65
Bosch tassimo t46 coffee maker
I have a problem with my bosch t46, I just bought it in Canada and returned to Aussie yesterday, when I plug it in all good orange light place disc in the green light comes on, but when i press and hold button both bottom red lights flash?
Any ideas what it could be very frustrating Thanks in Advance
Jan 06, 2012 | Bosch Tassimo TAS4511UC Coffee Maker
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I...
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine,All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I have since put the machine away and have stopped trying to use it. Any help that you might be able to give would be greatly appreciated. Thank you Tandie Grant
Oct 26, 2010 | Braun Tassimo Espresso Machine/Coffee...
My tassimo will not read the bar code. I have tried different pods and cleaned the reader and it still doesn't go past the yellow light
I have the same problem. It works for one coffee after it's been switched off for an hour or two.
I calle Tassimo and they are sending out a new one!
Apr 14, 2010 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo - plug it in and no lights
have you switched it on on the back of the tassimo
Jan 13, 2010 | Braun Tassimo Espresso Machine/Coffee...
Wont heat or make coffee lights keep blinking
All lights flashing -
The machine is not prepared for use. Check water level, T-DISC.
Also try this link for the user manual:
http://www.scribd.com/doc/2421389/Braun-Tassimo-User-Guide
Another thing, try unplugging the machine; wait 5 minutes and plug back in.
Refer to the user guide for further diagnostics.
If you're still having problems contact customer support - number in user guide.
Thanks for trying Fixya.com
Mike...
Nov 29, 2009 | Braun Tassimo Coffee Maker
Braun Tassimo Coffee maker quit working
Hmm if not in covered try
http://rapidshare.com/files/238159116/Braun_Tassimo_3107_Disassembly.pdf.html?killcode=397312781122638452
Mar 15, 2009 | Braun Tassimo TA1400
Tassimo Goes Right From Auto to Standby
I called Tassimo customer service and they helped me solve the problem. The sensors need to be reset
1) unplug machine
2) Before turning on, push and hold the START button
3) Release the START button after the machine is on
4) Insert T-disc and close lid
5) when it goes to AUTO , press START
this fixed my problem
Dec 31, 2007 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
1,158 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
