Question about Whirlpool LER4634J Electric Dryer
Dryer is over ampimg and tripping breaker. Run load amps are 27 amps. Motor is 5.5 amps with belt on and 4.5 amps without belt on. The heater ohms out at 9.1 ohms which compares to a new heater. All wires are tight and connection are good. I jumped out each safety and timer and amps did not change. What is the RLA of the motor and will the resistance change when the heater warms up?
  • 70 Answers
Have you changed out the 30 amp breaker in the panel? Run the unit and feel the breaker in the panel box, if it is getting warm, you need to change it. Sometimes they become "weak" and mis-read what the appliance is doing
Posted on Feb 19, 2009
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
My motorguide trolling motor keeps tripping the 50 amp in line breaker every time I turn it on high speed. It is a 75 lb thrust digital tour model. When I take it out of the water and run it on high...
All motors will draw higher amperage with varying loads. Your hi speed motor winding has probably shorted some its winding's without having gone to ground. It probably needs to be replaced to get your hi speed back. I have run into similar problems in heavy commercial hydronic pumps. Best to have mechanic check it out. An OHM test with factory specs. will tell for sure.
Sep 04, 2013 | Electrical Supplies
Amana electric dryer LE8317W2 tripped circuit breaker. Orange wire fried at end by heat element and was off terminal end. Also the purple wire was fried at thermostat end. I cleaned up connections and...
These units are totally repairable and will run for ever. Need to assume that other damage has occurred as a result of the failed shorted terminal connections.
Possible that the circuit breaker is defective caused by the dryer failure.
Assume that one of the components has shorted to the grounded frame of the dryer.
The 11 ohms of the heater is about right.
Confirm that heater element is not shorted to the dryer frame (heater housing)! This condition would have caused the initial wire terminals to fail and now trip the circuit breaker!
Use an ohm meter and check resistance between hot leads on back of dryer. Check resistance between each hot and neutral.
There is a switch located on the motor that connects power to the heater. When the motor is running the centrifugal switch closes. This saftey circuit confirms that the blower is running before heat is turned on. Check that the switch is not damaged from prior terminal short circuit failure, Repair kit is p/n WPL-501218
Timer is the next check. Same thing confirm that no damage to the switch circuits has occured. Last check thermal fuses and thermostars for short to netural.
Hope this helps?
Jun 25, 2017 | Amana ALE643RB Electric Dryer
Electric dryer tripping breaker - thermostat heater shows no continuity - is that the problem?
No actually unless setting your meter to a pretty high setting the thermostat heater is going to show no continuity...the other part of that t-stat the main cycling will have continuity if good but as far as the t-stat heater (the smaller terminals on that t-stat) that will be somewhere between 6-20 thousand ohms.
Many things could make the breaker trip including;
A shorted heat element
a shorted timer
a shorted motor
a shorted wire
If it blows the breaker without the dryer even having to be on you should be looking for a broken and grounded wire to the cabinet(any metal part)
if it only trips once trying to start the dryer its probably going to be the heater,motor or some other component or even a broken and grounded wire
And much more that i care to type now
Oct 10, 2011 | Dryers
My dryer is about 5-7 years old. last three months, It will run for a couple of minutes and then trip the breaker. this will happen with or without heat. vent is clean, seems to be more an issue of how...
yes hes probably right,, once a machine gets bogged down by whats inside of it, thats usually time for a new motor , its trying to draw more amps than it can handle just to try and run properly,, when this peaks the circuit breaker in your panel it trips
Jul 07, 2011 | Whirlpool Dryers
I have a Kenmore 300 series elect. dryer that keeps tripping 30 amp breaker. Have already changed breaker wiring going from box to dryer and installed new motor.
Check your load/AMP capacity.
If you have other electrical appliances on ie. Iron, Heater, toaster, Kettle these will contribute to the over loading problem.
Old homes sometimes only have 40-80 amp capacity
Apr 19, 2010 | Dryers
Dryer won't heat up but tumbles. What could be
you could have a bad heating element, a tripped circuit breaker, a blown fuse in the dryer or a bad timer. you can check the element and fuses/ thermostats with an ohm meter for continuity.
Sep 17, 2009 | Dryers
Dryer trips breaker as soon as i try to start it.
Use or borrow a volt ohm meter and check for a grounded hot wire. You may also be exceeding the start up load on the 20 amp breaker. Test this theory (after you make sure that there are no ground faults) by starting the dryer in a "air fluff" mode without heat. If the dryer starts in the "no heat mode", switch the heat on - if you blow the breaker you know that the 20 amp breaker cannot handle it. Before you do any of the above - check your dryer manual for the service requirments. If you don't have the manual go to the mfg. web site and download it.
Feb 04, 2009 | GE DBXR463GB Gas Dryer
Hi I have a Roper electric dryer since 2000 never had a problem also had an electric dryer for 6 year before that never had a problem with breaker going off now its been happening frequently, all the...
You will neeed an AMP meter.
Take the face cover off the breaker box.
Very carefully, without touching any wires and frying yourself check the amperage on the wires (one at a time) coming off the breaker to the dryer. (While its running with a load of wet clothes)
If the amp draw is very close to the amp rating of the breaker (IE 30 AMP breaker dryer drawing 28.5 AMPs) then you likely have an issue with the dryer and s the amp draw fluctiates a little it pops the breaker.
Several things can cause this. Motor windings going bad, elements going bad, dryer in need of a thourough cleaning etc.
There could also be a short to ground with one component/switch that is only energised during certain cyles. Keep note of when it trips the breaker. If you notice a pattern, that will help determine the problem.
If none of this applies, and the breaker is just poping randomly without having an amp draw higher than its rating, then you have a bad breaker.
If you have no amp meter. You could try replacing the breaker.(With the same rating, DO NOT go higher unless you want a really big bonfire.)
Most breakers are less than 20 bucks.
Thats an easy job, and if will help you isolate the problem by knowing if it's the dryer or breaker.
Otherwise you must either have a good Volt/OHM/Amp meter to trace down the problem.
Jan 01, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
