Question about Frigidaire FRS26KR4A Side by Side Refrigerator
Hot water dispensing from Refrigerator
The water line was disconnected for about 3 years or more. We purchased the refrig. about 6 years ago. In replacing the filter, reconnecting the water line, and turning the water on, to our suprise...the water was hot! We ran the water for a while but it still is coming out hot and dirty. What is the problem?
It is a Frigidare (FRS26KR4A)
    Problem Solver:
  • 13 Answers
Call the manufacture or get a new fridge.
Posted on Feb 19, 2009
No water will come out of the door
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR41X10173 to stop this freezing and it comes with instructions .
May 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The water dispenser stopped dispensing.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in the door is frozen , GE has a dispensor heater which comes with instructions to install . Pt # WR49X10173 .
May 21, 2010 | Hotpoint HSS25GFP Side by Side...
Water dispenser does not work
May 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser does not dispense water GSS25LG
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 , with installation instructions , to keep this from happening again .
Jan 19, 2010 | GE GSS25LGM Side by Side Refrigerator
Kenmore s/s f/f; ice dispenser working; water dispenser not
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it doesleave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Oct 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Terrible Plastic After-Tast in Dispensed Water (Refrig)
If indeed it is stagnant water you have to find the water source tap off of your water supply. Then trace out the routing of the feed water line to your refrigerator. Turn off the tap, remove the line at both ends. You can abandon the existing line. Reroute the new line. or you can remove the old line and follow the same route. Reconnect the tap and refrigerator ends.
Jul 14, 2009 | Refrigerators
About a week ago, ice making slowed way down.
changed the water filter. cost $43 for a new one. crazy.
Jun 17, 2009 | Aspen Refrigerators
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Refrigerator model #gss25sgress Water dispenser problem
What you describe was a common problem with this model and one that still pops up. Your refrig *might* qualify for an upgrade under terms of a program GE initiated a few years ago. Call 800-432-2737 first it might save you a service call
Jan 06, 2008 | Refrigerators
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Frigidaire FRS26KR4A Side by Side Refrigerator Logo
110 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
