Question about SanDisk Sansa e250 MP3 Player
Couldnt turn offn now cant turn on
This is really a mystery
I own a Sansa Clip 4 meg
it down loads ok
and plays fine
but since i owned it
i could turn it off
but ..
some time it would resurect itself and turn on?
so i tried to reset ect.
and today at the gym?
i turned off on its own and refuses to come out of her shell?
tried to hook her the computer? nothing?
thanks for reading
  • finbar_02 Feb 20, 2009
    totcham
    Thank you for your help!
    Your advise was taken
    and lo and behold its working!
    Thanks again!
  • 4 Answers
Just wait for the power to go off..it should be empty within the day or so...then check back on it...try turning it on...if u see a note saying it needs recharging then ull be fine
Posted on Feb 19, 2009
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
http://forums.sandisk.com/sansa/
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
Two problems 1)My sansa clip shut down on its own and when I turned it back on all files were erased. When plugged into the computer the media player still showed 3/4 of the memory still used on the clip...
Its not usles, you can delete the files while on the computer. After having in plugged in you can access it like a flash drive. Then you can open the music folder and delete as you will. Depending on what kind of files you have on it, its possible that i wont recognize the format of the file. I think though from what you've said that it did work, and then stopped playing songs that worked before. So I don't know what to do about that. I don't use the normal way of loading songs onto my Sansa clip MP# player though. I just dump all of my songs via direct transfer into the music folder in the player itself
Oct 04, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
I cant turn volume up on my sandisk clip
My problem seems to be a damaged volume button. Once I tour the volume down (the down button is fine) I could not increase back de volume.
This is a palliative sollution. You need to reset you Sansa clip to get the volume set to the "middle" of the range. To steps are:
1) clique in the "home" button.
2) navigate to "settings"
3) select the "Reset All" option and confirm it.
Apr 02, 2009 | SanDisk Sansa Clip MP3 Player
My mp3 player seems to be stuck
Maybe you daughter did something with it and made a mistake. Ask someone to get it fixed for you
Feb 22, 2009 | SanDisk Sansa Clip MP3 Player
How can i get videos from my pc to my sandisk sansa NEED HELP cant play videos
down load them legally or use lime wire and it could be legal or it could be illegal or some other down loader or copy them from your own dvd collection
Feb 12, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Sans Clip 1 Meg Player
I would try seeing if you can update the firmware, you can find Sandisk's Sansa Clip Firmware updater off to the right on this web page:
http://www.sansa.com/support/sansa_clip/faqs
Let me know how that works for ya.
Oct 10, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip does not show up on computer
I had the same problem all you've got to do is first turn on the sansa clip.Then go to settings. After that scroll down to USB mode (second from bottom) then it woul probably say auto detect. Scroll down to MSC then hit enter. If that doesn't work try MTP mode.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
It froze
Sansa Clip Player has some problem. I tried 4 sansa clip players (I purchased at Best Buy for Thanksgiving), and none of them work. Dont even try to exchange them, just return them back.
Oct 24, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e250 MP3 Player Logo
95 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
