Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Badger insinkerator 5 just buzzes wont work.
Took out all food and looked for something stuck in blades. Used handle to turn blades, and used wrench in hole in bottom to turn it.. It moves freely and even reset button on bottom.. After all this I am at a loss still wont work.. Please help.
  • 1 more comment
  • Anonymous Mar 25, 2009
    I have the same problem with mine. The flywheel turns just fine and the water drains. It just buzzes when you hit the switch.
  • gnikmot Apr 04, 2009
    Same problem same model.  Drains just fine.  Blades will move using the supplied wrench at the bottom.  Unit just hums when switched on.  If left on for too long, it will stop humming, and have to be reset with the reset button on the bottom of the unit.
  • caloula Apr 19, 2009
    I had the same problem. Buzzing but not working.  I stuck my hand in and realized a spoon was stuck between the wall of the unit and the blades.  Pour a little of oil and was able to jiggle it out.  It's working fine now.
We just ran into the same problem. We fixed it by taking the disposal out and just cleaning all of the debris out of it. It was just stuck because of the fish tank rocks that were stuck between the "blades" and the wall of the disposal so they were just in there preventing the "blades" from spinning.
Posted on Mar 28, 2009
    Novelist:
  • 152 Answers
First have a friend with electrical exp. and a voltage tester to check the voltage to the unit. If its receiving the proper 120 volts on a stand alone 20 amp circuit then my suggestion is that the motor is in short "burned up"and in need of replacement.
It is not cost effective to have this unit rebuilt, unless it is still under warranty.
A new unit is only around $120.00 and your handy man friend should be able to remove and replace this unit.....because hes your friend.
Posted on Feb 20, 2009
It just buzzes
grinder blade is probably stuck or in a bind. Take a socket wrench with extension and from the top (sink), turn the nut and blade inside the disposal by hand to free it up. Can also unplug it and reach inside to see what may be lodged in the disposal (rag, bone etc).
Oct 22, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger insinkerator, 1/3 HP does not start. Please help...i try the red button and didn't work...the blades aren't rotating....
Use wood broomstick handle down into disposal.
Wedge broomstick against side of sink opening and rotate blades free.
Or use allen wrench on bottom of disposal to free cutter blade.
If blades rotate freely and disposal has power, and reset is not tripped or will not reset, then disposal is bad.
I wrote ez disposal replacement steps:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator is humming and not working. I bought the wrench and keep playing with it but it it stuck. My son insists that the engine is seized but I feel if it were seized it would not turn on at all....
Your Badger 5 spins the blades counter clockwise. If you want to dislodge an item stuck in their, you have to spin the blades clockwise. I use the handle end of my plunger to do this. If it turns free with the handle, it should work when you turn it back on. If you don't hear it hum any more their is a little red reset button on the bottom of the motor housing you must press to reset it.
Sep 03, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I have a Badger 5 (5-81A). The motor is humming when it's turned on, however, the blade does not turn. The blade does seem to move freely. Tried reset and hex key but still nothing.
you have something stuck in it more than likely,, use the key ( unplug it first) and turn it backwards,, keep looking inside with a flashlight for the lodged object once you see it,, remove it,, sometimes the key won't work if its something caught in the blades themselves, so use the handle end of a broom or plunger with a wooden handle to push on the blade itself to turn the unit over
May 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 1/2 HP garbage disposal. When I turn on the power switch it just makes a humming sound but doesn't engage. Is there a reset button somewhere on the unit that might need a...
There should be a reset button (circuit breaker) on the bottom of the unit. It sounds more like the blades are stuck. Pull the plug on the unit and use an allen wrench on the manual blade turner on the bottom of the unit. If the blades are stuck, you will have to try and loosen them with the allen wrench. If you do get them loose, the question then is what was holding them. Could be debris in the ISE or something broken like a blade. Keep the unit unplugged when working on it.
Sep 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: It hums but doesn't work. The wrench moves freely ...
If the blades move freely with the wrench and stick and motor hums then it sounds like it is time to replace the unit. Have you tried the reset switch? If it is humming than it is probably not tripped but worth a try. Hope this helps.
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Badger 7 just buzzes but blades manually turn.
well you need to take the trap apart and clean out as far as the badger if you can turn with allen wrench the it may be time for a new one they are warrentied it will buzz then throw the in line breaker a button on bottom just push in
Sep 10, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 that will not turn on. The blade freely turns by hand, but unit will only hum like the motor is locked. Suggestions.
Use and allen wrench underneath in the center of the disposal. Does the shaft turn freely? If it does, the capacitor is bad. If the shaft won't turn, there is something stuck inside the disposal.
Jul 01, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The blades on my Badger 1 insinkerator don't move. The motor hums when turned on. The reset button stays out when pushed.
You will need to free the blades by inserting the food disposal hex key or a 1/4 Allen Wrench into the very bottom of the disposal in the center. After inserting the wrench you need to turn it all the way in both directions to free what has the blades held up. It may be hard to turn but afterwards pull the debris out from inside the disposal. Hit the reset button and it will work. Do not keep turning it on until you free the blade and then reset.
Jun 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In-sink aerator makes buzzing noice and wont work even after pressing the reset button.
Are you sure the blade is turning? If its not, there is a hole in the bottom you can fit an allen wrench into to turn the motor and break it free again.
May 27, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
3,000 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
