Question about Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551
Wont build pressure after rebuild
I have model 919.167243 15 gal 1.5 running hp. anyways i was sandblasting and i thinki ran it to long with out cool down and it started to make a higher picthed sound and would build pressure over 20-25 tops. i bought a head gasket kit and new rod kit which includes the the sleeve and ring and new rod with bearing. i put it back together and same thing no pressure build up any help or advice i checked the big vavle at the tank and the piston moves freely in and out. plz help
    Scholar:
  • 169 Answers
Check valve plate and gasket for anything broken, also when you installed the piston into the cylinder did you push it up from the bottom? if the sealing ring is installed with it folded down towards the crankshaft will allow air to blowby, it needs to be facing up to pump correctly.
Posted on Nov 26, 2009
    Champion:
  • 205 Answers
If you assembled things correctly disconnect any hoses and check for air leaks and check the inlet and discharge valves are good
Posted on Feb 26, 2009
Will not build up pressure
worn out pump on the compressor, or leak in tank.
Jul 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Pressure in the tank only builds to 30 psi
Bad check valve. But I would check the regulator, by turning it down to about 10 PSI and running it and see if it builds again, if that works then it is the check valve. But from what you are saying I would replace the check valve anyways.
Jun 05, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
Dec 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Wont build pressure over 25 psi after rebuild
sounds like the belt is slipping have you checked the inlet and discharge valves also could be bad and leaking or stuck or installed wrong
Feb 19, 2009 | Air Tools & Compressors
Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551 Logo
197 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
