Question about The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
Radius of an ellipse
I know major axis .910 and minor axis .710 how do i find the raduis of both axis
  • The Learning... Master
  • 7,993 Answers
Sorry to say it but the question does not make sense. A circle is a figure that is perfectly defined by the knowledge of its center (or centre depending of the English you use) and its radius.
An ellipse is perfectly defined if you know its two foci (plural of focus) and the length each of its two axes (major and minor).
Is it the perimeter, the area, the parameter p of the ellipse you are lookong for.
Hope it will help you focus on your real the question.(The pun is intended)
Posted on Sep 07, 2009
How to calculate the volume of a oval shaped spher
The volume of a solid of revolution can be calculated by making use of some methods of integral calculus. For that you will need the exact equation of the the surface that limits the solid. Nothing you can do on a calculator.
However for the spheroids there exit formulas you can use on a calculator.
  • For an ellipsoid
If a, b, c are the lengths of the semiaxes (length of semiaxis=half the length of the axis)
V=(4/3)PI*a*b*c
  • For an oblate spheroid
An oblate spheroid is the solid of revolution formed by the rotation of an ellipse about its minor axis (here an image of the cross section from Wikipedia).
V=(4/3)PI*(a^2)*b
  • For a prolate spheroid
A prolate spheroid is the solid of revolution formed by the rotation of an ellipse about its major axis
V=(4/3)PI*a*(b^2)
Feb 27, 2014 | Office Equipment & Supplies
Area/volume of a ellipse
I am afraid I do not understand what you want exactly (ellipse, parallelepiped?). The area of an ellipse with semi-major axis a and semi-minor axis b is given by
Area=PI*a*b
Nov 25, 2013 | Ellipse Visor 91810 - Red Line
Futaba PULSCALE Manuals
I'm using Futaba Pulscale 2000.
I can't change the unit from Inch to MM. and I got problem to change " R" ( Radius ) to "D" ( Diameter ) into each axis of " X " or " Y " individually.
Please help to solve this problem. Thanks so much.
Sep 10, 2013 | Toys
1 Solution for "the raduis
Pi R Squared
3.1416 x 9
28.2744 sq CM
Jul 15, 2011 | Computers & Internet
Find the equation of the hyperbola which satisfies the given equation center(1,-2) transverse axis to the x-axis transverse 6 and conjugate axis 12
I am not quite sure how the major axis of your hyperbola is directed and i do not know if the lengths you give are measures of the major and minor axes or the measures of the semi-major and semi-minor axes. So I am giving you the equations and the graphs so that you can decide for yourself what is appropriate for your problem.
Major axis parallel to the X-axis
Equation and graph
Center is at x=1 and y=-2, semi-major axis length is a=6, and semi-minor axis length is b=12
Major axis is parallel to the y-axis
Equation
Center is at x=1 and y=-2, semi-major axis length is a=12, and semi-minor axis length is b=6.
I trust you can customize the equations to fit your need.
Mar 24, 2011 | Office Equipment & Supplies
Find the equation of the ellipse whose center is at (0,0), one vertex is at (3,0) and one end of minor axis is at(0,2)
find the volume of the largest cylinder with circular base that can be incribed in a cube whose volume is 27cu.in?
Mar 18, 2009 | Computers & Internet
What is the forular/working out of- ellipse with a long axis 2.500mm and short axis .850 (double the 0.425 radius) the area is 1.669 thus the area of the part circle is 0.835. what is the formular
I'm not sure what your ellipse looks like but the equation for the area of an ellipse is given by:
pi times the long axis times the short axis
pi = 3.1416
The length of the long axis is from the center of the ellipse to the outer edge of the ellipse
The length of the short axis is from the center of the ellipse to the outer edge of the ellipse
Hope this helps Loringh
Nov 01, 2008 | The Learning Company Achieve! Math &...
Can't transform from polar to rectangular
The e is the same, it is the exponential. According to Euler's relation
e^(i theta) = cos(theta) + i sin(theta), where i is the imaginary unit.
When represented on the complex plane (x,iy) the point (cos(theta), sin(theta)) is at the extremity of a vector of length 1 and making an angle theta with the real axis.
In (plane) polar coordinates, a point is defined by the radius r, and the angle, theta, it makes with the x axis, measured in the trigonometric (counterclockwise) direction. It is structurally equaivalent to representing it in the complex plane as r*e^(i*theta). Since r is the measure ot is radius, and the theta is it argument (angle). The complex notation is used for its convenience when adding vectors (as is AC circuits)
That is the theory.
I am inserting a clipping from the book to show you how to convert between polar and rectangular coordinates.
Oct 10, 2008 | Casio FX1.0 Plus Calculator
Tomtom 910
you must have it set up for the fastest route.... It does not know what you are driving or how wide it is.. you may have to reset it to only go on major highways.
Jun 04, 2008 | Tomtom GO 910 GPS Receiver
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Logo
418 people viewed this question
Top The Learning Company Computers & Internet Experts
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
