Question about GE JKS06BFBB Electric Single Oven
GE Oven JKP26GP2 getting F2 error, even when not in use. I ohmed out the Temp sensor at room temp it is 1091ohms. The other 2 sensors check NO and NC. It's 100 bucks for a new Temp Sensor.....just don't want to buy 1 if that isn't it. It seems to be the most common fix, but I haven't seen anyone else getting F2 when the oven is not in use!
  • stinkylee Apr 26, 2009
    I am willing to purchase and replace the sensor. Where is the sensor located?
  • 70 Answers
F2 usually means the temp sensor is not working. here is a link to "F" codes.
http://www.repairclinic.com/0078.asp#JennAir
It has many manufacturers listed,so scroll to the GE ones.
The reason it beeps when not in use is b/c the EOC is reading the error in the part.
Good Luck!
Posted on Feb 19, 2009
EO F2 The oven will not start or stop. I can not get the oven to work but it will beep with this EO F2 message sometimes.
Hello Sonya,
The E0-F2 error code means that the oven temperature was higher than it's supposed to be. Usually the oven overheats because of a defective oven temperature sensor and the sensor should be checked. 11_3_2011_2_07_54_pm.jpgthis is what the sensor looks like...it is located within the oven chamber(usually in the left side) to check it,it needs to unplugged and using a mulitmeter set to measure ohms,check the sensor to be between 1060-1100 ohms at room temp. if the sensor is way lower/higher that 1060-1100 at room temp the sensor is bad and needs to be replaced, if the sensor is within that range then the control board is the problem.
GENE
Nov 03, 2011 | Whirlpool RBS275PD Electric Single Oven
I need to see if I can obtain a manual for the PLT059-2 GE model gas oven. We are getting F2 and F3 errors but are unable to identify what those mean and the oven will not work properly.
The F2&F3 error code both point to a defective oven tempature sensor being bad...to check the oven sensor unplug it from the wiring harness and use a digital meter to measure the ohms rating on it...check it at room tempature and check for between 1060-1100 ohms at room temp.
If it s way higher or lower that 1100ohms the temp.sensor is indeed going to be bad.
The sensor is in teh oven baking chamber and can normally be pulled out and checked after removing from inside of the oven
Sep 06, 2011 | Ovens
My oven displayed F5 then F3 code I believe after a nearby lightning strike, When installing new sensor with supplied wire nuts I found black marks on oven side connector. Immediate F4 error code when...
When checking the sensor it shouls be checked at room temp (even if power off) at it should be between 1060-1100 ohms at room tempature. 16 ohms the new sensor is shorted the F2/F3/F4 all relate a faided sensor and the F5 error code says the clock (electronic oven control) is defective.
Test the sensor again at room temp...if only 16ohms its no good and will throw the F4 code everytime again a good sensor measured at room temp should be between 1060-1100 ohms
GENE
Sep 06, 2011 | GE JTP15 Electric Single Oven
F2 error code while in self-cleaning mode
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Mar 20, 2011 | GE JTP15 Electric Single Oven
My GE Profile electric oven keeps shutting off on me, it shows a "F3" code on the screen. What does this mean?
Sorry to read about your problem, I hope this helps you out.
your F3 means: Oven temperature sensor open you cannot reset this type of problem.
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Jan 02, 2011 | GE Profile JTP18 Electric Single Oven
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
F2 code on GE selfcleaning oven
The F2 fault code generally means the Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor Might want to check the oven sensor for high resistance. Get a ohm reading of the oven sensor at room temperature and tell me what this reading is.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | GE Ovens
GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
Error message
Webgenie, the code should read F3, which indicates a open oven sensor (over 2900 ohms). The sensor should ohm out at 1080 ohms at room temp. Best thing to do is replace the oven temp. sensor. Easy job..Catriver..post back.
Sep 24, 2006 | GE Profile JTP56 Electric Double Oven
GE JKS06BFBB Electric Single Oven Logo
710 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
