Question about Sony DAV-S300 System
Remote control will not work
My remote control will not work. Bought a new one and it still does not work. My guess is the remote sensor has gone out. It will only work if I hold the remote against the front of the unit.
Same problem but new remote won't work at all. I have a Magnovox TV and Journey's Edge remote.
Posted on Feb 19, 2009
Dsd 933 remote not working
Thunderstorm do not affect the remote control. It might have effected to your TV. Infrared sensor section circuit inside the TV should be checked.
Feb 09, 2013 | Televison & Video
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
Remote Stopped Working
It is possible the IR sensor is bad. Most of the time if it is a remote issue, the light on the remote will not light up. Does the remote that came with tv still control any functions? I would try the remote that came with the tv, and then go from there, but it sounds like your IR sensor has gone out on you.
Mar 31, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Nunchuck is not working even though connected to wii remote
The sensor may be gone.  The best way to test this is really easy and pretty cool to do.  Take two candles light them and then place them a little further apart than the wii sensor is.  If you are able to use the remotes then the sensor bar needs to be replaced and if ther is still nothing I would try replacing the controller because the infered led's may have gone out.  If that still does not work then the sensor decriptor in the wii has gone out.  Nintendo should be able to help you with that part.  But I do not think that it is the Wii.  I feel that your sensor bar is bad.
May 28, 2009 | Nintendo Nunchuck controller for Wii
Remote control not working
If the new remote is not working either, it sounds as if the problem relates to the sensor on the TV combo.
If you bought it new last Xmas you should have some warranty left. I would get it looked at asap before the warranty expires.
Dec 02, 2008 | Televison & Video
Zenith Z25x31d
Hi
maybe you have defective sensor in remote control! or you have defective crystal in remote control! all you have to do is to replace a new one each.
Thanks!
Aug 23, 2008 | Televison & Video
Can't change output source and tv sensor wont work
souns like the ir sensor board is gone, shopjimmie.com may have one ,they are probably around 15 bucks and real easy to change ,its one connector i believe ,i have not found any universal remotes that work with ilo yet either,good luck i hope i was of help
Apr 23, 2008 | iLO 3200 32 in. LCD Television
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
No remote works my tv?
Sounds like it could be the remote sensor in the set but a look at the data line comming out of the sensor with a scope would tell ya if thats so.. Thney are the omnly ones to fix an rca in your area as its still under a warranty and you can take it anywhere thats authorized for rca unless you bought it as is and if you did you should have tested the whole set.
Apr 03, 2006 | RCA 32V550T 32" TV
Sony DAV-S300 System Logo
417 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
