Question about Sony Bravia KDL-32V4000 32 in. LCD TV
My Sony Bravia often goes snowy on HDMI with my PS3
Ok. I got a new Sony Bravia KDL-32V4000 32 inch tv for and connected my PS3 to it. The normal scart connection works fine and so does the HDMI in 580p. When I put it into 720p or 1080i, it works but every now and then the screen flashes black or goes all snowy for a second or two. This kinda sucks when your playin games or watchin a movie. I have a 37 inch Toshiba also but the HDMI doesn't work at all in 720 or 1080 on that. I'm using a 20 euro HDMI cable from gamestop if that makes any difference. Any ideas?
5 Suggested Answers
SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
Posted on Aug 25, 2007
  • 231 Answers
SOURCE: No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Posted on Dec 16, 2007
  • 1779 Answers
SOURCE: proscan 40 in full 1080p hdtv 60 htz tv and i cant
No one that I know of broadcast in 1080p yet. Only Blue-Ray DVD's. The set can't produce what's not there.
Posted on Jun 15, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: cannot remove caption
Press the info button once on the HXD890's remote control (button top right on the main circle in the middle). All should then dissappear.
Posted on Dec 16, 2009
I have a sony bravia 40 inch hd tv. i also have a comcast hd box that always worked on the tv through the hdmi. One day i was having trouble with cable box so i unpluged it to reset it. now my tv will...
Your PS3 working doesn't mean a thing for the cable unless you are using that cable for your PS3. I would bet you have a bad HDMI. They are pretty sensitive to being bent. Try replacing that first. The other thing to check is to first make sure you have the proper input selected on the TV for where you have the HDMI plugged into on your TV.
Aug 25, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
40" Sony Bravia has intermittent audio failure.
I have a KDL-46VL130 with the same problems. Audio on the HDMI connection turns on and off intermittently when I have it connected with my ATT Uverse rcvr. I check w/ Sony online support and they led through the standard troubleshooting process ... which I knew going in would not fix the problem. Ultimately they told me to try a new HDMI cable first, or try a different video source for the HDMI, other than my ATT U-Verse reciever and see if the problem persists. Having seen other articles on this issue, i am almost certain that is not going to fix the problem... and to think that I paid $2000 for this thing.
Dec 13, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
May 25, 2009 | Sony Bravia Z KDL40Z4100 TV
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
BRAVIA TV KDL-40V2500
i had the same problem and the only way i could solve it was to disconnect power from the tv, let it "reset" then it would be ok for a bit. the problem went away entirely when the cable company updated its software for its hd box. might be coincidence....
also, pre-update, the resolution wouldnt automatically set correctly. If I turned on the tv to a hi def station, it would set to 480 and only set to 1080 when i changed to a normal station then back to the hd. then it was fine. again, after the update from the cable company this went away.
Sep 28, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL 40X2000 HDMI both cutting out
Sounds like a handshake problem with the HDMI outputs on the devices. I have never seen BOTH HDMI inputs have the problem. It could be a problem in the TV where the HDMI signal is processed or the HDMI jacks may have been stressed and this is why you have an intermittent problem. By stressed I mean that the jacks have been bent by inserting the cables wrong or pulling up or down on the cables when they were plugged into the unit.
Jul 20, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-32V4000 32 in. LCD TV Logo
270 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
