Question about Sony KDF-50E2000 50" HDTV
Projection Lamp I have just installed a new projection lamp and it is properly in place. We followed all the instructions and the TV picture is beautiful. My problem is that the warning that the lamp is nearly out of life still shows up when we turn the TV on. I cannot find my owners manual, so I am at a loss on what to do. THANK YOU! Fran Earle
Open menu, go to settings, scroll down to " Lamp Replacement " move right to start . Message will ask if you replaced lamp? Put in Yes, enter and your done.
Posted on Apr 16, 2009
    Novelist:
  • 184 Answers
Sadly, in this TV, you have to get into the servicer menu of the TV to reset the lamp timer. Until you do this, the prompt will continue to come on. Check with Sony 1800-222-SONY for assistance.
michtech
Posted on Feb 19, 2009
  • DennisM66 Nov 20, 2010
    You do NOT need to go into the service menu or call Sony. This is a simple fix. Click on blue "menu" button on your original Sony remote. The displayed menu now appears on your screen. Then scroll down to "Setup". Once in "setup" then scroll ALL THE WAY DOWN until you see "Lamp Replacement" (you have to scroll all the way because the "lamp replacement" option is hidden). Select "Lamp Replacement" and you'll be asked "has the lamp been replaced?". Click YES and you'll remove the nag screen when turning on the TV on.
Change lamp on TV model WD52525 reset does not work
follow this steps and fix it. God bless you
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Jul 31, 2013 | Televison & Video
How do you replace the lamp for a panasonic PT-50LCZ70
Hello
To replace the lamp of your Panasonic Projection TV do the following. Read these instructions carefully and then try to do the job.
1. Turn the power off, wait until the power indicator turns off blinking red, then unplug the power cord from the wall outlet and confirm that the area around the lamp unit has cool down.
2. Remove the front cover procedure. Place your finger tips under the cover and pull it from the projection display.
3. Before loosening the lamp cover screw, first read the caution and warning labels in the lamp cover. Then loosen the lamp cover screw by using a screwdriver.
4. Loosen the lamp unit screw with a screwdriver. Then grasp the lamp unit, Figure 2, by the lamp unit handle and slowly remove it from the projection display.
5. Insert the new unit being careful being careful of the insertion direction. Press in the arrow mark making sure insertion is done correctly.
6. Replace the lamp unit and cover screw. Tighten the unit cover screw with a screw driver.
a. Properly dispose of the old lamp. Please see the operating instruction of the projection display unit.
b. NOTE: attached the lamp unit and lamp unit housing door securely. If the lamp unit and the lamp unit housing are not attached securely, the protective circuit will be activated and the lamp will not turn on.
7. Replace the front cover.
The second step, after lamp replacement is to follow the three steps procedure described below:
Warning: Perform lamp time reset only when the lamp has been replaced.
In order to complete the lamp time reset procedures:
1. Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button the projection display or the remote control to turn the unit on.
2. While pressing the VOL - button, hold down the PIP or the SPLIT button on the remote control at the same time for more the 5 seconds.
3. When the reset procedure is complete, the projection display screen will show the following message "Lamp time was reset to 0."
Notes:
1. The writing in the screen may be different from the actual screen described above.
2. When lamp time reset is finished, the lamp indicator goes out.
OK.
Feb 23, 2011 | Panasonic PT-50LCZ70 50" HDTV
Hi, i changed the lamp on my LG LCoS Projection TV Model 71SA1D. Everything was great for about an hour or so. The lamp warning indicator reappeared and the TV shutdown only to come back on within a minute...
it may be something with the new lamp or the projector overall. try to turn it off, disconnect the power cord, press the power button for about 10 seconds, remove the lamp and reconnect it making sure it is properly installed. then place the cover securely and try to test it again. you may also need to reset the lamp time for it, refer to the manual of your device for the instructions.
Dec 26, 2010 | Televison & Video
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Tv picture and sound goes away for about one minute and then comes back. After another two - three minutes, the process starts over again, and again. Please help if possible, Thanks!!!
When the bulb goes off with the sound. The lamp is starting to fail andyou need to replace it. Wear gloves when replacing the lamp. UseXL-2400(part # F93087500) replacement lamp. For informationvisithttp://sonystyle.com/tv for US residents andhttp://sonystyle.ca/tv for Canada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Put the new lamp in its place. Mount it securely and take extra care not to touch glass portion of the lamp.
  5. Turn the knob back to CLOSE and secure the cover.
  6. Put the outside lamp cover back in its place.
  7. Turn on the TV
  8. Browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Disposethe used lamp properly. It contains mercury and disposalis regulated..Contact your local authorities for proper disposal.
Sep 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture and sound go off for a few seconds and then come back on.
When the bulb goes off with the sound. The lamp is starting to fail and you need to replace it. Wear gloves when replacing the lamp. Use XL-2400(part # F93087500) replacement lamp. For information visithttp://sonystyle.com/tv for US residents and http://sonystyle.ca/tv forCanada residents.
  4. Putthe new lamp in its place. Mount it securely and take extra care not totouch glass portion of the lamp.
  7. Turn on the TV
NOTE:Dispose the used lamp properly. It contains mercury and disposal isregulated..Contact your local authorities for proper disposal.
Aug 23, 2009 | Sony Televison & Video
My Sony 51 Inch when I hit the power the standby button just blinks with no picture or sound
You need to change the projection lamp. Use XL-2400 replacement lamp..for information visithttp://sonystyle.com/tv for US residents and http://sonystyle.ca/tv forCanada residents.
  5. Mount it securely and take extra care not totouch glass portion of the lamp..Use gloves as a precautionary measure.
  6. Turn the knob back to CLOSE and secure the cover.
  7. Put the outside lamp cover back in its place.
  8. Turn on the TV and browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Dispose the used lamp properly..it contains mercury and disposal isregulated..Contact your local authorities for proper disposal.
Aug 14, 2009 | Sony Grand WEGA KDP-51WS655 51" Rear...
Replaced lamp, no picture, turns to red light
please make sure to place Lamp Door/ Cover after installation of new Lamp in TV.
Jun 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replacement lamp
Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on disengages.
Remove the screw securing the lamp cover with a Phillips head screw driver
Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.
Exercise caution when removing the lamp unit to avoid injury to your fingers
Replace with the new lamp.
Place the removed lamp into the empty box of the replacement lamp. Do not touch the front glass of the new lamp or its
receptacle. This may shorten the life of the lamp and reduce the picture quality.
• Push the lamp unit back to its original position.
• Tighten the screws firmly on the lamp unit. If they are loose, the TV may not operate correctly. Install the front cover. There is also a video on youtube just do a search on how to install a projection lamp. Hope this is helpful
Aug 22, 2008 | Hitachi 50V715 50" Rear Projection...
Sony KDF-50E2000 50" HDTV Logo
496 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
