Question about ASUS A8N32-SLI Deluxe Motherboard
Cant connect to web with ethernet cable
I have been trying to connect to the internet with an ethernet cable but it keeps saying network cable unplugged, if you have any idea of how to solve, or if i need to elaborate to make it more clear please email me at patocket@yahoo.com your help will be grealy appreciated
  • Peter Steiert
    Peter Steiert May 11, 2010
    Have you attempted uninstalling the adapter and reinstalling it?
  • 741 Answers
Well what setup do you have, single computer? Make sure your network adapter works, is the key..run cat 5 cable from computer to modem and modem to wall outlet. If possible try your network adapter on another computer.
Posted on Feb 19, 2009
My travelmate 240 will not connect to the internet via an ethernet cable. I have a bt home hub with a wireless laptop and PC with ethernet cable running OK. I have tried with the known good ethernet cable...
The best way to check if the computer can access to Internet is to boot the computer to "Safemode with Netwroking", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select "Safemode with Networking" from the Advance boot menu. Try to connect to internet. If you are able to connect to Internet then the issue is with the firewall on you computer, contact the firewall manufacture or do settings. If you are still unable to connect to Internet, then the internet setting are not correct, you may need to contact the ISP or try reseeting the Internet Explorer.
Thanks and Regards,
Anil.B.R
Sep 07, 2010 | Acer Computers & Internet
Install software without a cd rom drive
Connect an Ethernet cable between the network-port on your computer and one of the LAN ports on the router.
Now, you have a "direct" connection to the web-server that is "inside" the router. Open your web-browser, and connect to the web-server, and then you can run the "Wireless Networking Setup Wizard" to create your wireless network, i.e., pick an SSID and a password, and enable "WPA" (Wireless Protected Access) security.
Now, you can disconnect the Ethernet cable, and you can "find" the SSID that you have chosen.
May 28, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Networking Problem
It is not uncommon for the network adapter to become faulty and stop working. Since you've checked the cable and it is still listed in device manager as working properly, I would add a PCI ethernet port to your computer, then disable the faulty one in device manager. They can be picked up for around $15 locally and even cheaper on the web.
Jun 14, 2008 | EliteGroup P4VMM2 Motherboard
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Enthernet connection
Ethernet connection is a LAN or a CAT cable
One end of that cable will connect at the back of ur router box that u will have with u or u will get it from ur ISP .
and the other end of that cable goes to the back of ur pc in the jack which says LAN or try to plug it in any socket which fits properly.
u will a light that will start flashing at the back of ur back when u plug that cable in
to check whether u system supports ethernet connection or not
1. right click on my computer
2. goto properties
3. goto hardware
4. goto device manager
5. u will find network adapters there
click on the plus sign on the left side of network adapters
plus sign will change to minus
under network adapters look for an ethernet adapter or network controller
or 10/100 or 10/1000 fast ethernet NIC ( network interface card )
if u have one , then ur pc supports ethernet connection
U just have to connect the ethernet cabel to ur router box and at the back of ur pc and u just have to open internet explorer and ur internet would start working...
if u dont have ethernet cable with u or ur system does not have an ether net socket in ur system , u can goto any computer shop and get an ethernet cable and a socket for ur system
If u dont want to do that , u can go for a USB cable connection with ur pc or a wireless connection....
reply back if u face any further problems
Feb 19, 2008 | Computers & Internet
Connecting ps3 via t-mobile web n walk
now then or you hav to do is plug it to your pc go to internet connection t mobile properties then advanced allow to share to other connections then plug your cable to your pc from your ps3 you might have to turn your windows firewall off or just change the settings if you dont want 2 turn it off
Dec 09, 2007 | Sony Playstation 3 (PS3) Console
Set up of adsl router
Try resetting the device to the default factory settings. Then see if you can get an IP address, either wireless or ethernet, to configure the router through its web interface.
Nov 18, 2007 | Belkin (F5D5231-4) Router
Not able to connect to the internet
Please list the model of the network hub you are using.  Also is a "hub/switch" or a routher.  Also are you using a DSL or Cable internet connection?  Please provide a little more details.
Oct 26, 2007 | NetGear (GS608UK) 8x1000 Mbps Networking...
ASUS A8N32-SLI Deluxe Motherboard Logo
89 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
