Question about Polaroid i830 Digital Camera
I HAVE A I634 AND WHEN YOU TURN IT ON AND GET READY TO TAKE A PICTURE IT SAYS CARD LOCKED AND I CAN GO NO FURTHER, HOW DO I UNLOCK THIS?
    Sergeant:
  • 180 Answers
On the sd memory card there is a little switch on the side. try moving that to the other position and see if that works
Posted on Feb 19, 2009
Nex 6 is saying image database file not ready
Try these solutions to fix image database file not ready:
1. Format the card within the camera itself.
2. Erase everything from card and then re-insert it in the camera.
3. Replace the card with new one
4. Check whether card is locked or not. If it is locked then unlock it.
5. Switch off the camera and then Turn it ON back again.
I hope any one of the solutions have helped you to solve the problem.
The above solution is brought to you by: http://www.rescuedigitalmedia.com/fix-card-error-image-database-file-not-ready
Apr 05, 2013 | Sony Cameras
Says "card locked"
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 13, 2011 | Polaroid i634 Digital Camera
I have a polaroid i634 6.0 12x .when i try to take a picture i get a notice that the card is locked. what does this mean and how do i correct this
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Nov 21, 2010 | Polaroid i634 Digital Camera
My Canon A460 says the Card is locked. The lock switch on the card is set to unlock. I have another camera with a similar card. Both cards work in the other camera. neither card will work in the A460 both...
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another device.canon cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Jun 27, 2010 | Canon PowerShot A75 Digital Camera
When trying to take a picture it says card locked.
The SD card lock/unlock switch has been moved to the lock position. Remove the card and slide the switch (along the edge of the card) to unlock. If it is in unlock, try sliding the switch back and forth a couple of times. Reinsert the card and it should be ready to go.
Apr 06, 2010 | Samsung Digimax S500 Digital Camera
Says card locked when trying to take or delate a picture???
Your card is protected against deleting now... You have to get it out, just push it slightly, it will jump out of slot and then move small slider on right side of card to 'unlock' position. Put it back and enjoy.
Jul 21, 2009 | Canon PowerShot A75 Digital Camera
Unlock card on digital camera
I JUST HAD THE SAME PROBLEM WITH MY CARD SAYING ITS LOCKED.....TAKE YOUR CARD OUT OF YOUR CAMERA AND TURN IT WHERE THE LABEL IS FACING YOU AND ON THE LEFT SIDE IS A SMALL TAB THAT IS COLORED DIFFERENTLY THEN YOUR CARD....SLIDE IT UP TO WHERE ITS NOT ON THE LOCKED SIDE....
May 03, 2009 | Polaroid I533P Digital Camera
CARD LOCKED
There should be a small toggle along the end side (it is tiny and easily missed, but it is there, I just checked my memory card / mine is 4GB SD card from Sony) that you can swtich to unlock and your images may come back that way.
Look for it this way, hold the card face down it should be on the back edge where you use your thumb or finger to push it into the slot on your camera.
Mar 03, 2009 | Canon PowerShot A540 Digital Camera
Polaroid i830 Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
