Question about E-Machines eMachines Desktop PC
Dead emachine t3104
The problem i have is not from the power supply, i turn the pc on and the fan on the power supply kicks on for a second as well as the cpu fan. After this happens the psu seems as if it freezes and i can not turn it off without unplugging the psu. However i can get the fans on both to turn on only if i unplug the 4-pin 12 volt plug is removed from the motheboard, any help with this would be great.
  • bamash0109 Feb 19, 2009
    i have installed a known good psu, is there anything else i could try?
  • 131 Answers
In most cases this means that your motherboard is fried, but if you can get your hands on another power supply, try plugging it into your board just to be sure.
Posted on Feb 19, 2009
E machine t3104 cd drive and hardrive dont work fans and processor fans come on though.
Substitue different power cables for the hard drive and cd drive. Also check that power cables and data cables are firmly connected at both ends.
Feb 09, 2013 | E-Machines (T3104) PC Desktop
Use a DMM and test the power wires for hard drive and CD drive should read around 12VDC ( peak). DMM=Digital Multi Meter... If theres power then check connections remove them then replace them.
T5020 emachine seems to have dead power supply- how can I confirm?
If the PSU fans only work for a short time usually this means that the PSU is shot
If you suspect your power supply has gone bad, there are a few basic things you can do to test it. First, plug the computer in and try to start up the computer. If the computer can start up or shows signs of having power (the hard drives spin up, or the fans turn on) the power supply might be fine, and you may have an issue with your motherboard or RAM. If the computer won't start at all, open the case and then turn the power supply on and attempt to start the computer. Observe the motherboard to see if any lights turn. If no lights turn on and there is no sign that power is being supplied to any of your devices, there's a decent chance that the power supply has burned out. If your computer experiences periodic crashing, feel the case near the power supply to see if it is hotter than normal, and smell the air. If the case is much hotter than normal or you smell burning, your power supply might be overheating, and may be damaged. http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm hope this helps
Jan 01, 2013 | eMachines T5020 512MB DDR PC-3200 Desktop...
Have an older emachines T3104. The hard drive died, so had to reload OS (XP Home). The emachines website no longer lists the sound drivers for this machine. Where can I get them?
If you know the manufacturer of sound chip, go to their web site and get the driver.
You can look in the device manager to find the sound chip manufacturer.
Apr 06, 2011 | E-Machines (T3104) PC Desktop
Died. nothing comes on, so not dead drive. switched out power supply, so not dead power supply. the switch on the front - blue led only comes on when plugged in lower right two prongs of 8 (4x4). So, tried...
short power switch pins on mother board, reset bios, short green wire to black wire on ATX connector with all drives etc.. power cables disconnected to test power supply. i suspect you have a dead motherboard.
Jun 20, 2010 | eMachines ET1161-01 PC Desktop
Yellow Light
Emachines are bad for having failed power supplies and motherboards. Test your power supply, watch this video.
http://www.metacafe.com/watch/729606/how_to_test_your_computers_power_supply_psu/
Aug 03, 2009 | E-Machines eMachines Desktop PC
Replaced dead power supply computer still dead
hi
most power supplys are protected against faults when they are connected to damaged equipment
so it possibly just protecting its self
disconnect everything from the PSU except your MB
try to turn on
if your pc boots ok
re connect everythng else one thing at a time attempting to boot each time
when it wont boot you have found your fault
Feb 07, 2009 | E-Machines D2046 PC Desktop
Emachine w2646 won't power up
Put the hard drive in another computer as a slave drive or second on cable select. boot and then access the hard drive. Your data should be there.
Jan 08, 2009 | E-Machines eMachines W2686 PC Desktop
Fast Fans nothing else
If your system won't even beep when powered on, your most likely problem is a bad power supply. You can get a new power supply fairly cheap - a good one is here http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023
If you install a new power supply and the symptoms don't change, your motherboard is probably shot.
Feb 17, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
118 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
