Can't find parts for fujita 2.5hp split system
I have a 2.5hp split system fujita and when it was fitted it worked perfectly, however when I went to use it again the system wouldn't work. thought it was out of gas but found out it worked if you activated it manually. Rang the sevice spare parts mob and they quoated $180 for the board in it. there started the problems because there is 2 boards in one for the remote which is the 1 that is blowen which they didn't know about and the main board ($180). Still waiting for the spare parts mob to get back to me!!!!!! Help
My Fujita remote stopped working, you would unplug the unit & turn it back on, the system would go into a test of the airflow lever (opens & shuts), remote would not turn on unit, found that on back of receiver board where 3 wire plug connection is, solder joint had shorted across from r to - . scratched this away with screwdriver carefully & all ok.
to get to board you remove 3 screws in filter cover & 3 plastic covers with 3 screws below air flow lever, just lift up cover enough to remove 1 screw holding remote receiver board in.
Posted on Mar 09, 2013
  • 400 Answers
I am pretty sure you would only need to buy the remote board, but before you do, you could try to resolder all the joints on this board. It is a small board with a couple of LED and remote sensor. Then make sure it is plugged in well, and give it a try.
Posted on Mar 12, 2009
Do I set my fujita split system on Sun or rain for cold air?
i would'nt be putting on rain as it will start spitting out water everywhere.
Jan 06, 2018 | Heating & Cooling
HOW I CONNECte remote control to fujita air ASW-H18B4/HS
If it the correct remote control for the unit, point remote to unit and press power button this is normally followed by a beep to confirm unit has received command,
if this does not work please check battery's to ensure they are still fit for purpose
Dec 24, 2015 | Heating & Cooling
Fujita 3hp split system Compressor won't start
Ohm out the compressor...if it is new & getting the correct power, should be under warranty. You should not have to install a hard start kit on a new unit.
Dec 14, 2013 | Heating & Cooling
Fujita split system air conditioner filter outdoor unit
Pull the filters make sure it's not freezing and catching the fan blades, if not then the fan motor needs replacing
Sep 27, 2013 | Heating & Cooling
I have lost the manual for my fujita 2.5 split system and all i want is w what to press on the remote control..... as from Winter to summer Cheers Clare
You decide what temp you need.
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Jan 06, 2011 | Heating & Cooling
Anyone have a Fujita Installation manual
it should be all coded on the head and compreser for the sparky
Dec 17, 2009 | Heating & Cooling
Spilt air conditionerl
Hi deabreu5. I have a spare remote for the fujita split system model: KFR I also have the instruction booklet but no manual.
Mine lasted for 3 years and no cold air comes out anymore. I'm going to have a crack at fixing it myself somehow. But a spare remote came in the box so I'll sell it to you if you like.
email me.
Feb 03, 2008 | Heating & Cooling
Heating & Cooling Logo
791 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
