Question about Reddy Heater-30-55,000 BTU Variable
Heater, 35,000 BTU Reddy Heater won't fire up.
It worked fine 2 days ago. Can I adjust the screws in back to make it start.
  • 181 Answers
There is only one adjuster screw in the back of the unit.most likely your problem is in the rotor.you need to take the back plate off then you should see 6 more screws on the metal plate.remove them to get to rotor.the air vains should drop to the bottem without any help.usualy they pick up moisture for the air from sitting.pull the out and soak them in lacquare thinner for a few minutes then wipe them off with a paper towel.install them one at a time and check to see if they drop or not,if they don't i use a piece of 280 grit sand paper and carefully sand the marks off them.don't get to carried away though.sand a little then try them.once you get them to drop by them self reinstall the cover and try to ignite the unit again.
Posted on Feb 24, 2009
Reddy heater won't stay going there are two screws on back what are they for. It's an older one think it's 1000 btu's
Those screws are: 1. the one with the hole in it is a relief valve to allow excess air to escape. 2. the solid plug is to be removed and a low pressure gauge inserted.
Then, you adjust the air pump pressure to factory specs. If not properly set the heater will not function properly.
Follow this link for instructions http://www.reddyparts.com/pressure.htm
May 27, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Problem: Will not spray fuel through nozze. Lines are not clogged. Have cheecked spark plug. It is firing. Special note: It is Series 35,000 Reddy Heater.
You can try adjusting the pump pressures, but it does sound more like the pump went out on you. Have you checked to see that the shaft to the pump is turning? I am not sure how that mates up with the motor be it a set screw, or coupling, but would check it over the pumps are generally not an issue.
Dec 20, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Dec 21, 2009 | Heating & Cooling
Reddy heater 35,000 torpedo heater
unit needs photo cell,or cell is dirty.to check photo cell disconnect the two blue wires from reset switch nad put a wire between where the blue wires were connected.that takes the photo cell out of system.fire unit up.if it stays running photo cell is bad,change it and all will be right again
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Types of fuels
YOU COULD RUN ON # 2 HEATING OIL BUT WOULD NOT RECOMMEND DIRTY AND MORE LIKELY TO GUM ALSO DOES NOT GENERATE SAME BTU PER GAL I WOULD STICK WITH KERO
Jan 16, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
249 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
