Question about Kwikset 907 907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt
Lock works in reverse
When you push the lock button the dead bolt opens and when you enter the keypad code it unlocks. What do we do to repair this?
You need to set the door direction jumper pins inside the unit. From LH to RH or vice versa depending upon your door.
Posted on Jun 01, 2009
I could help you if I had the original manual. Do you or anyone else have the manual that could be copied and sent to me? I have a fair amount of experience with this product. Enough that promted me to buy a used version, 907-15 powerlock. But, it came with no instructions. That is all I need to re-learn how to reprogram or help others with issues. If so! send to stewart1966@clearwire.net.
Posted on May 16, 2009
Defiant keypad deadbolt
The instructions should make this clear, but if not contact Defiant for an explanation.
Apr 15, 2014 | Locks & Locksmithing
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
My unit is not lit up. Impossible at night to see numbers for code
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Oct 10, 2011 | Weiser Lock Powerbolt 1000 Lock
My keypad won't light up when door is locked whe you push lock won't light up green
Good luck--and please provide feedback if this helps!
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Just want to change 4 digit code to new one
Do this, with the door open:
Remove cover from assembly by sliding cover up and off. You will then see the program button.
A programmed code can be from four (4) to eight (8) digits long.
Up to 2 user codes can be entered.
Excess delay in the programming steps once started will cause unit to beep twice and will require you to restart from step (a).
Programming the first User Code:
a. Press the program button on the interior unit once.
b. Enter in 4 to 8 digit code onto the keypad.
c. Press the "LOCK" button to save code.
d. Extend the bolt by pressing the "LOCK" button and re-enter the code to test. The bolt should retract to the unlocked position. If it does not unlock, repeat steps (a) through (c).
Programming the second User Code:
a. Press the program button on the interior unit twice.
After programming in just one new code, the existing old code may still work. I suggest that if this is the case, that you program in two codes to make sure that the old one is over-written. You may try programming in the same new code both times if you don't want to have two codes.
Here is a link to the installation and programming instructions that I excerpted the reprogramming instructions from:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For further assistance or warranty information: call 1-800-677-5625 USA & CANADA
or visit, www.kwikset.com
Jul 26, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
To unlock the bolt no code is needed... just by pushing the lock button it unlocks what do i have to do to make it function proporly
You need to reset the lock, so it will be set to the correct handing (left or right hand door).
Open the door and extend the lock bolt. Remove the battery. Press the reset button three times and wait 20 seconds. Push and hold the lock button, while inserting the batteries. Hold the lock button until the bolt starts to move. Allow the lock to complete it's learning cycle.
Program a new code and test.
Jan 09, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
The backlights on our Kwikset 909 are not lit. Is this controlled by one of the switches or could something not be installed correctly?
Dec 17, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
Keypad door lock does not work..?
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
  • Enter the permanent factory code.
  • Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
  1. Enter the five digit permanent entry code into keyless entry keypad .
  1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
  1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
      • 9/0 — no memory recall
      • 1/2 — memory seat position 1
      • 3/4 — memory seat position 2
      • 5/6 — memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
  • Keyless Entry Keypad Does Not Work Properly
  • Circuit.
  • Keyless entry keypad.
  • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • Oct 04, 2009 | 1995 Lincoln Town Car
    Kwikset 907  907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt Logo
    506 people viewed this question
    Top Kwikset Locks & Locksmithing Experts
    Iron
    Iron
    Ted Rishel
    Level 1 Expert
    Richard Roth
    Richard Roth
    Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
