Question about Kenmore Refrigerators
My kenmore refrigerator side by side
Hello my Kenmore side by side fridge is working from the refrigerator side but not from the freezer everything is melting from there its still cold but not cold enough to freeze.  The setting is turned all the way up on the freezer. this was manufactured 2002 model number 51252102. Please help me thank you . similar problem... water started leaking; then freezer stopped working; today fridge stopped... the fan comes on sporadically;kenmore s/s 53892?... thanks
  • 117 Answers
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
My kenmore fridge 253.53612300 was set on the highest # for cooling and barely worked for about a year now it is freezing everything in the fridge what is going on
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 19, 2010 | Kenmore 53612 / 53614 Side by Side...
Have a Kenmore model 106.5702602 side-by-side for 1 year and can't get rid of freezer odor...have tried everything and can't put anything in freezer that isn't affected by this smell. Help!
the air blows from freezer to fridge side and then returns from fridge to freezer,so it could be and usually is something on fridge side causing odors or funny tasting ice cubes,check under bottom draws on fridge side,what kind of odor is it?
Nov 28, 2009 | Kenmore Refrigerators
My kenmore side by side,freezer part is working good but no cold in the refrigerator side ,can any one help me?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Not cold
Hello
I am also having a same problem what i will suggest you youcan see the bucket at the back side of the fridge,switch off ur fridge and turn out that bucket and then turned it back,if it is also not work then the wire is coming to ur fridgger check that wire by tester that the current is coming to that wire or not
This will help you
Thanks & Regards
May 23, 2009 | Kenmore 57029 Side by Side Refrigerator
My Kenmore fridge/freezer side by side isn't staying cold
Ok so we just had our Kenmore fridge quit cooling , everything in the freezer defrosted , and we lost a lot of food,BUT my husband ordered a part #8201786 which is a starter , and installed it and it worked! The fridge was clicking but it just wouldnt kick on, and the fan still worked. There are websites that you can order the part from, It cost $63.05 with tax!!!! good luck
Mar 15, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator is not cooling
Hello hazraan
Welcome.
You said your Kenmore model 60852990 freezer is working but refrigerator is not cooling.
Lets try a couple of ideas.
Is your freezer filled up where the packages are covering the air vents in the rear of the freezer?
Refrigerators and freezers must share the cold air and circulate between them. If the freezer is packed full with not enough space at the air vents in side it, the fridge will get warmer!
Next,Turn off the fridge and freezer controls, and then go to the breaker box and turn off the breaker to the fridge for 5 minutes!!!!!
Then restart it and the fridge and freezer controls.
This should reset the system and solve the problem. let me know if either were the case.
If either was the reason,it now will take some 8 to 12 hours to gets back to temperature.
Waiting your response.
Huuum, Please remember to leave a rating.
Oct 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sounds like it has a defrost problem.  Check for thick frost buildup on the back bottom panel in the freezer first and let me know what you find so I can steer you in the right direction.  Also, give me the entire model # from the sticker inside fridge.
Oct 17, 2007 | Refrigerators
Refrigerators Logo
299 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
