Question about Maytag CWE5800A Electric Double Oven
One side of oven burns food, other side doesn't get done
CW5800 was here and new, unused, when we moved here. Cooks unevenly. One side of item I am cooking burns, other side not done. Bad problem.
5 Suggested Answers
SOURCE: Oven bakes unevenly and burns food
You wrote- "Recalibrate the controls". How?
Posted on Apr 21, 2008
trav1856
  • 57 Answers
SOURCE: gas oven that cooks unevenly
no, if it came with something to make it work on propane, that's fine, just make sure it's adjusted properly...otherwise you'll get a lot of sooting, and orange flames instead of blue.
Posted on Dec 06, 2008
barkencoa
  • 3463 Answers
SOURCE: What is wrong if the oven is not cooking food evenly?
If it is not a fan assisted oven, then I would say that one of the side elements has gone, u will have to locate and check it,or put the oven for a couple of mins, then check the elements they should both be hot.
Hope this helps.
Plz rate this solution.
Thanks.
Posted on Dec 31, 2008
SOURCE: Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Posted on Dec 27, 2010
mc1bean
  • 3053 Answers
SOURCE: we set the oven temp,
Hello, warren
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Ignis AXL 905/IX oven and prob is food is cooking on top but not below. Two elements at top. Inner on when in oven mode, outer on in grill . Bottom of oven not warming evenly and burning top of food
Your bottom element is not working and that is why foods placed on top heat up but the undersides are not affected as much.
You need even heat on both sides of the food. Get a new element and replace.
Sep 06, 2015 | Ovens
Oven cooks too fast and burns the food
My electric oven, Garland master 200 only reach a maximum of 250* and I only saw 1 of 3 elements turn red
Dec 14, 2012 | Garland Convection Oven - MCO-NAT Gas
Sep 26, 2009 | Ovens
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Jul 24, 2009 | Amana AEW3530DD Electric Single Oven
Hope this helps.
Thanks.
Dec 31, 2008 | Moffat E32 Full Size Electric Convection...
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Concealed oven
consealed bake means that the bake element on the bottom had a metal plate above it to make it easier to clean and to allow you to use the lower racks without burning the bottom of your food. To use, you want to make sure that the oven temperature that you set has been reached before putting in your food to be cooked. You also should put the racks one notch lower than you normally would. If you do this, you should have no problems with your food cooking unevenly.
Jun 28, 2007 | Amana AOCS3040SS Electric Single Oven
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Maytag CWE5800A Electric Double Oven Logo
350 people viewed this question
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Maytag Oven Expert? Answer questions, earn points and help others
