Question about Kicker KX200.2 Car Audio Amplifier
Kicker kx200.2 protect mode at high volume
Recently (about a week ago) my kicker kx200.2 amplifier started going into protect mode at high volume. ive been running it the same way for probably a month now without problems until now. its run at 2.2 ohms with the gain set to 2/3-3/4 somewhere around there. i have it powering 2 8ohm mids and 1 4ohm coaxial on each channel. with the multimeter i get a reading of about 2.2 ohms on both channels. when i turn my head unit up to about 90% or a little less, the kicker amp goes into protect. if i turn it back down for a few seconds it restarts. does anyone have any ideas as to the problem? there are no reversed polarities, no shorts on the speakers or power terminals, and everything seems to be connected properly... any help? thanks
  • Perry Babin May 11, 2010
    Disconnect the speaker wires 'from the speaker terminals' of the amplifier (not at the speaker or any other point). Do one channel at a time. Does the amp go into protect with only one channel connected at a time?
    Does it only go into protect mode with one specific channel connected?
SOURCE: kicker zx1000 only plays at low volume
your subs are blown
Posted on Sep 16, 2008
blackberries
  • 80 Answers
SOURCE: I need to know what mid speaker is good for my 4
mainly less battery draining/power consuming! specs seem to be the same
Posted on Feb 27, 2009
  • 113 Answers
SOURCE: my amplifier keep clipping
start with the lowest settings on all the adjustment knobs and turn your radio up to about 3/4 of the volume and go from there
Posted on Jul 06, 2009
  • 12 Answers
SOURCE: my amp goes into protection mode at high volume
Hi does the amp return to normal operation once the volume is lowered? If so it sounds like the amp is seeing too low an ohmage due to the way the subs are wired & they are drawing too much current so the protection circuit intervenes to prevent damage.The minimum ohmage this amp must be operated at is 2 ohms so if you are running at 1 ohm this will cause the problem you are experiencing.
Cheers, acbva.
Posted on Nov 15, 2009
alicantecoli
  • 22326 Answers
SOURCE: when you turn up the
the output transistors are going home ,they have been overdriven and burnt out
Posted on Sep 22, 2010
Zx750.1 kicker amp cutting out
Also check your fuses. there may be a fuse for the in-tank fuse.
Jan 05, 2014 | Kicker (ZX750.1) Car Audio Amplifier
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
I have a 300 Watt dual amplifier connected to one 12" kicker dvc sub at 2 ohms. Every time the volume is turned up the protect light turns on. I had 2 of these kickers wired to a Rockford amp a week...
Then you have found your problem. It's internal on the amp. Protection circuitry issue. Have it Benched at a shop with the same impedance you are running it at. If it benches ok, check your ground, it should be no longer than 18" and go directly to the floor frame, not a seat bolt. You should also be running at least
4ga power as well. Hope this helps.
Jan 11, 2011 | Dual 300W Class AB Bridgeable 2-Channel...
I have a kicker amp and my power light will come on once the music starts but not even a full sec later it fades into protect mode den bak green den red it jus keeps rempeating itself kan u help me
Maybe theres a loose connection in the power ic. causing the vivration of the casing when you on the volume control. you need a qualified technician to fix your problem.
Jul 02, 2010 | Kicker ZX10001 Car Audio Amplifier
My kicker kx 1200.1 keep clicking to protection mode back and forth when it power. There is a clicking sound comming from the amp...is it a major problem to fix? This just start happening when i was listen...
Look for a frayed speaker wires. Look everywhere. Start where you can see and then look under carpet, under seats, trunk and everywhere wires go throgh a hole in steel frame. Any minor connection between the two speaker wires will cause high-power systems to go into protection mode. Wires can be damaged by long-term vibrations of your car, people stepping on badly placed wires under carpet, moving seats (when adjusted) or even rodents bitting on the wiring. Look closely and you will normally find it. Also look closely where you connect your speaker wires to the amp. One small strand of wire jumping across to another terminal will cause a short and cause protection mode.
Nov 19, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
ZX700.5 cutting out at 60% volume
I figured out the problem, the front right tweeter wire was pinched behind the mounting bracket. everything is now working perfectly.
Sep 22, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
My amp goes into protection mode at high volume
need more info, make and model of amp and subs please
Feb 18, 2008 | Kicker DX350 Car Audio Amplifier
Kicker KX200.2 Car Audio Amplifier Logo
73 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
