Question about iLO MP3 Player
Video mpc player
My slyvania smpk88548 freeze up when I Turn it on
You need to find the system file and reflash the player. I'm looking for it now if I find it I will post a link
Posted on Mar 05, 2009
I Had a notice saying 'error creating DX9 allocation presenter'. 'create device failed D3DERR_NOTAVAILABLE' everytime I turn a video on MPC-HC 1.5.0.2827
Have you checked with your directX version to see if there are any errors encountered? To do this, go to Start/Run/dxdiag.exe
Run the tests and see if it has any problems in there. If there are no problems, then the culprit might be in your MPC configuration. Sometimes re-installing it with defaults enabled will remove any codec errors, so you can get back to watching movies.
Incidentally, have you tried VLC player? It has a rather large range of video and audio formats that it play, plus it's got the best price : FREE! :)
Anyways, hope that helps.
Cheers from NZ
May 23, 2011 | Computers & Internet
Tip
How to do Blu-ray playback using Media Player Classic Homecinema
Media Player Classic Home Cinema is an extremely light-weight free program for Windows. It looks just like Windows Media Player v6.4, but has much more additional features. You can use it as a Media Player Classic Home Theater. MPC Homecinema supports a wide range of decoding formats and file formats, following are the details:
Supported Decoding:
MPEG-1, MPEG-2 and MPEG-4 playback. Media Player Classic is capable of VCD, SVCD and DVD playback, without the need to install any additional software or codecs.
It has built-in codecs for MPEG-2 video and codecs for LPCM, MP2, AC3 and DTS audio, and also contains an improved MPEG splitter that supports playback of VCDs and SVCDs using its VCD/SVCD/XCD Reader. A *.mp4 and MPEG-4 Timed Text support added. An AAC decoding filter makes MPC suitable for AAC playback in MP4.
MPC Home Cinema also has H.264 and VC-1 with DXVA support, DivX, Xvid, and Flash Video formats is available in MPC HC. MPC can also use the QuickTime and the RealPlayer architectures. Media Player Classic supports native playback of OGM and Matroska container formats.
Supported Video, Audio and Image File Formats:
WAV, WMA, MP3, OGG, SND, AU, AIF, AIFC, AIFF, MIDI, MPEG, MPG, MP2, VOB, AC3, DTS, ASX, M3U, PLS, WAX, ASF, WM, WMA, WMV, AVI, CDA, JPEG, JPG, GIF, PNG, BMP, D2V, MP4, SWF, MOV, QT, FLV
To make commercial Blu-ray movies playable with Media Player Classic Homecinema, one thing you have to do is using a blu ray disc ripper to remove copy protections before your playback. The following contents will give you the detailed steps.
Note:
If you are using a powerful PC, you can do the following "Directly Copy". When playback, MP Classic Homecinema will automatically download codecs as needed, so you are able to successfully play m2ts files directly copied from the BD disc, which have the same quality as the original.
1. Load Blu-ray files to Pavtube Blu-Ray Ripper
Three ways are available – "BD/DVD ROM", "BD/DVD Folder", and "IFO/ISO".
2. Select output format
Click on the dropdown list at the end of "Format", then follow "Copy">"Directly Copy".
Note:
If you are using a slower PC, we suggest you not to select "Directly Copy", because your slower PC will attempt to play the output m2ts files, but the sound does not keep up. So other formats supported by Media Player Classic Homecinema are recommended. To remain the high quality of a Blu-ray movie, you can choose "HD Video" as output format as below:
3. Click "Settings" button to adjust audio and video parameters
Note that this option is unavailable if you are using "Directly Copy". Generally speaking, the default settings are able to satisfy your needs basically, but if you have higher expectations of the output files, you can adjust all the following video and audio parameters according to your own requirements.
4. Click "Convert" button to start Blu-ray ripping
As soon as the ripping work is finished, you can get the output files for MPC Homecinema via tapping "Open" button. After that, you can import the files to MPC HC for playback. Have fun.
Additional Tips:
More than "Directly Copy" and format conversion, Pavtube Blu-Ray Ripper also supports "Full Disk Copy", which enables you to get a standard Blu-ray structure ready for burning.
on Apr 20, 2010 | Audio Players & Recorders
Everytime i put videos in slyvania mp3 touch it always says file format error.
You need to convert any videos you upload to your mp3/mp4 player to a format it will support, refer to your mp3 player manufacturers website for the screensize and supported video type and convert them. You can use the free Freemake Video Converter to convert a video to a supported format and screensize. Good luck.
http://www.freemake.com/free_video_converter/
Mar 02, 2011 | Audio Players & Recorders
Downloading music on coby mp3 player
media player are the two words you need to know
Jan 15, 2009 | Coby MPC-848 MP3 Player
Kareem
u can not put videos or movies on that kind of player
Jan 03, 2009 | Coby MPC-848 MP3 Player
My mpc hard drive freezes
Sounds like the hard drive either has bad sectors or has corrupted data and it needs to be formatted.
If checking for errors or formatting doesn't help, you may need to replace the drive. Depending on the hard drive that is installed, it may be getting to the end of useable life cycle or has damaged sectors and causes the MPC to lock up. It may also be that the controller board on the drive is failing.
Check the drive either with the built in utility or connect it to a computer and use a non destructive test utility like HDD Regenerator that runs from a bootable CD on a PC.
Cheers and good luck.
Dec 25, 2008 | Akai MPC-4000 Plus Production Center (w/80...
Can u please answer my coby mpc-854 512mb problem
I have issues every time I remove the battery. Under settings there is an option for USB mode. The default mode does not seem to recognize the device as a file storage device. Try the other USB option and you may have more luck (Again, the USB option is found on the MPC player, not on thecomputer)
Aug 25, 2008 | Coby MPC-848 MP3 Player
Coby mpc-854 512 mb
My coby c888 says No Files so therefore there is no music.
What do it do?
Coby mpc-853
For the most part all the onse that we've had have been doomed, either a cold soder joint or a volume key sinking into the body and sticking at zero. The battery coil may be out of place, so try bending that back in place. If nlot, I don't know what's wrong.
Sep 03, 2007 | Coby MPC-848 MP3 Player
Won't turn on, something I clicked.
tech support at tele 1 800 681 2629 or by email at techsupport@cobyusa.com good luck
Apr 09, 2007 | Coby MPC-848 MP3 Player
69 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
L Pfaff
L Pfaff
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
