Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3 Front Loader Washing Machine tumbler
The washing machine is making a clunking noise. The drum is intact with the two springs on the top and the two shocks on the bottom. The problem is when you open the washer door the metal basket that spins seems to have become disconnected from the drum it rides in. Any ideas?
  • dain123 Mar 21, 2009
    i can't find the plastic tumbler arm that goes inside the drum of a kenmore HE3T.  seems like an easy replacement.  Mine broke off.
  • 188 Answers
The metal basket (inner basket) has a broken spider (these are the support brackets that hold the basket to the bearing shaft). The inner basket will need to be replaced and the front and rear shell of the drum may also need to be replaced depending if any other damage has been done. It's a big job, about 2 hours for a good tech.
Posted on Feb 19, 2009
The noise thats coming from the machine its a like rubbing thumping noise. comes on when i start the washing cycle and spinning cycle.
noise from tumbler humm
which brand and make of front loader
then someone can answer the question better
Jun 14, 2016 | Washing Machines
My Kenmore elite 110.22992100 has started making a loud clunking noise switching from wash cycle to rinse. It is also shaking more than normal is this an easy fix or is major work needed? Thoughts?
Vibration and clunking can be caused by a number of things,
In this case though, first check the bearings at the back of the drum, if the drum is wet and theres a grinding noise major fix.
check the concrete blocks are tightly bolted on and there are no broken springs on the machine.
Check the belt and motor tensioning.
Feb 11, 2015 | Kenmore Washing Machines
What's broken to make washing machine drum unlevel
If this is a front loader washer then the springs holding the drum in place (inside the washer) are weak and off balance or the bearings are damaged.
Need some detailed mechanical check. See this post on this topic.
Front loader washing machine shaking vibrations Laundry Room Forum...
Aug 07, 2014 | KitchenAid Washing Machines
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
HI,WHEN MY WASHING MACHINE SPINS IT IS SO LOUD AND MAKES A CLUNKING NOISE.WHEN EMPTY AND I SPIN THE DRUM IT FEELS LOOSE.CAN YOU HELP WITH THIS PLEASE. THANKYOU.
Yes
Either one of your springs have broken at the top of drum.
Or the dampers under the drum have failed.
Possibly both.
You can get to your top springs by removing lid.
Dampers access is via the underside.
Remember to disconnect power and water before opening up machine.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Washing Machines
How do i fit the drum suspension spring on my font loader ariston washing machine
If you have already remove the top cover, front cover and back cover of the washer. You can gain access to the bottom portion of the tumbler. There you can jack up the tumbler with a jack of some sort, so that the tumbler is higher easier to latch on the spring to the hooking holes and not have to struggle with the tension of the springs.thinkfixya.pnghen put them onto the hook holes.
Jan 10, 2011 | Ariston Technologies Washing Machines
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
567 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
