Question about Frigidaire Affinity ATF7000E Front Load Washer
ATF-7000 is my washer. I cleaned the filter because I was getting the e-20 code. I took off the bellows to get at it. How do I get the bellows back on the tub. Or better yet how do I get the spring back on?
I figured it out myself!!! Your Guy was not any help at all and will never use your services again. It was a waste of money!!!!!!!!!!
Posted on Feb 19, 2009
Im getting af62 code on my atf 7000 washer
Thank you for your post, friend!
I understand that you are receiving an "AF62" on your Frigidaire washer. However, it appears "AF62" is an invalid error code. I would reset your appliance which can be done by flipping the household breaker off for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "AF62". I look forward to assisting you. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
I have a kenmore EH4t front load cloths washer. The code is F02. What does it mean?
F02 is for not draining correctly. Here is what you need to do:
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Sep 19, 2011 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Error code F02
Check this for one Kenmore machine, this is what done:
11. Remove pump
Keep us updated.
Apr 25, 2011 | Washing Machines
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Where is the filter in this washer?
Welcome to FixYa.
To answer you question " where is the filter in this washer " ? It is located behind the lower panel under the door in front.
Here`s how to check it and clean it...
**there is also a bellows with a back flow ball at the bottom which should be inspected. I`ll show you how to check & clean once you proceed through these steps**.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
Now You should be good to go. Re-attach the lower panel and you`re back in business.
** The back-flow ball I alluded to above is inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Oct 22, 2010 | Kenmore HE2 Plus Front Load Washer
Washer Odors of Mildew
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I,m getting a f-20 code duet sport washer
The F-20 is junk in the pump. Remove screws under the bottom to get the kickplate off. Clean out the pump filtera048311.jpg8f4a713.jpg0a688ab.jpg
Apr 01, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
2007 honda odyssey oil change and transmission fluid recommended change frequency
Have supplies ready(long stem funnel to reachfill hole, 4 qts honda genuine atf-z1, rags for drips)
1. First, park the car while its hot on a flat surface and turn the engine off. Locate the yellow transmission dipstick and remove it and wipe it clean.
2. Look for the the ATF fill plug and washer(below and to the left of the brake fluid reservoir) 17mm marked "ATF" and remove it.
3. Locate the drain plug(not the one on pointing towards the drivers front tire but its located on on the drivers side of the transmission pointing towards the passengers side and lying horizontally) and remove it along with the washer. Its blue and is a standard 3/8 square drive plug and remove it. Drain completely. (wait 15 min or so until ALL is gone and replace the plug after throughly cleaning the magnet that is attached to it).
5. Replace atf fluid(honda says 3.3 qts- but mine took 3.8 to bring to first hole in dipstick level-check while running(use honda z-1 fluid only-yes- its expensive).
6. Replace fill bolt and washer and tighten.
7. Replace dipstick, let engine get hot and recheck. Recheck again after driving a day or so.
Your done-good work, you saved a $100 dollars...
It can be changed for every 60000 miles..
Dec 19, 2009 | 2007 Honda Odyssey
Musty smell from rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Jun 23, 2009 | LG WM-2277HW Front Load Washer
F2 error code on my Kenmore Elite HE3 washer
Had this problem on our Kenmore machine.
This is what done.
11. Remove pump
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
184 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
