Question about Mitsubishi WS-55809 55" Rear Projection Television
03 mitsubishi medallion
Dont see a home theater mode on it. dont have remote. could that be a problem? i get into the menu stuff no prob? it works great with dvd or game?
    Novelist:
  • 184 Answers
The terminology for the home theater mode may have changed but there is a mode that locks the RF input out. You may need a Mits. remote to access it, but I think you can get to it thru the front panel buttons. I'll check on this and get back to you.
michtech
Posted on Feb 19, 2009
My mitsubishi is stuck on home theater mode an i
There should be Manual buttons on the tv on the side or bottom. There will be a menu button there also you will have to play around as i do not know what buttons make it go up and down ect. But you get the idea.. Good luck =)
Sep 29, 2014 | Audio Players & Recorders
NO VIDEO OR AUDIO ON ANY INPUT, BUT HAS MENU DISPLAY
If you try to change the chanel on the remote and you don't get snow, then your set is in home theater mode and stuck on EXT-1 input.
You will have to get into the menu under advanced settings and turn off Home Theater.
Hope this helps.
Thanks for using FixYa
Mar 02, 2011 | Mitsubishi VS-50609 50" Rear Projection...
My mitsubishi tv ws48613 has no audio or vidio. menu screen only and will not except channel memory
It sounds to me like your set is stuck in home theater mode.
You will need to pull up the menu and select advanced in the next menu, then navigate to home theater and turn it off.
The home theater mode fixes your Television to input one or Aux 1.
If you need any further help please reply to this post.
I hope that this helps you with this issue.
Thanks for using Fixya.
asnowman
Mar 22, 2010 | Mitsubishi WS-48613 48" Rear Projection...
Power light is on, menu info shows on screen, but no picture. Satellite does not show picture and DVD player does not show picture. Both are hooked through Bose home theater which seems to be working.
You should be able to use the device button on the remote control. If this does not work, try going into the menu and disable the home theater mode. The home theater mode locks the TV to input 1. I believe that it is in the advanced menu from the main menu.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 16, 2009 | Mitsubishi WS-65511 65" Rear Projection...
How do I change the input on my t.v?
I hope that this helps.
asnowman
Aug 01, 2009 | Mitsubishi WD-73733 73" HDTV
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
I have the 03 mitsubishi medallion that i cant get the antenna icon to let me click on it what do i do?
Look in your customer menu. Check to see if you are in the "home theater" mode. When in that mode, there are no tuner functions because in that configuration the RF input and tuner are not used.
michtech
Feb 19, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-5041
if you know someone with a dish network remote they have a cancel button.... i had the same problem and fixed it this way
Mar 17, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Input problem
your tv is set to "Home Theater mode" . Use "menu" key on your remote, go to "advanced feature", then go to "use home theater" then hit "cancel" to return to standard mode. If this does not work try unplugging the tv for 4 hours to return to factory default settings
Nov 07, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
