Question about Kenmore 63942 Dryer
Dryer was working then quit,
Power is good, the timer sounds like it is running while I press the start switch but motor does not start. this is a kenmore model 110.63032102 electric dryer
  • Kenmore Master
  • 3,361 Answers
Check for a broken belt.
Check door switch for continuity.
Check the thermal cutout switch for continuity.
Check the motor for lint blockage at the blower wheel.
Posted on Feb 21, 2009
Why does my dryer start but quit a second later
If it quits immediately after you let go of start button, then it isusually a bad timer or control board. The motor gets all its power during start from the start button or start relay, but once it is up to speed the motors centrifugal switch will flip, getting power from the run circuit. If there is no power supplied to run circuit (like when timer is off, or door is open) then the motor shuts off.
Jan 10, 2015 | Dryers
Amana dryer ned4600yq the dryer starts when the start button is pressed but doesn't stay on once the start button is released.
From what you describe, it could be several different problems. Rarely is it the push to start switch. The most likely scenario is that the centrifugal switch on the motor is not working correctly. The other scenario would be the timer. There should be a schematic located somewhere inside the control console. Look for the wires that go to the motor's centrifugal switch and the start button. Jumper the centrifugal switch on the motor so that the dryer thinks the motor is turning all the time. Then, test it by powering it on and pushing the start button. If the motor keeps running, then it's the centrifugal switch, if it shuts off, then it's most likely the timer.
Oct 19, 2014 | Dryers
Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Jan 07, 2010 | Maytag MDE6000 Dryer
Dryer will not start. I have power because the inside light comes on . The timer works .
Make sure the motor is not running when you try to turn the dryer on, they are very quite.
If the motor is running then your problem is a broken belt, or the belt has slippled off the motor pulley or idler arm pulley.
If the motor is not running then the problem could be the start switch or the timer switch even tho it is running they can have bad contacts.
Sep 27, 2009 | Whirlpool Dryers
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Gas dryer wont run
Hi. there can be many issue that can cause this type of interruption in normal operations. Lets go threw a few.One could be a faulty or dead motor. The timer board sends a signal to the motor once the start button is pushed. If the motor is malfunctioning or the wires that connect to the motor are lose or old and worn, the motor will usually click or buzz. the fault itself can be within the timer assembly or the motor itself. the best way to find out is to test the current flow at the motor by using a multimeter. connect this meter to the motor terminals and select the cycle and hit the start button. if the meter reads voltage at the motor and the motor clicks or buzzes, this will confirm an actual motor failure. if the voltage at the motor is weak or not there 0, this means the timer will need to be replaced. Next, I would check the door switch for its operational value. you can use the same method as i discussed above with the meter. use the terminals for testing on the switch. This could be a problem area as well. if the switch is malfunctioning, the dryer will not run at all. you will find the problem in one or both of the discussed areas above.
please rate and god bless.
Mar 25, 2009 | Kenmore Dryers
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Sep 22, 2007 | Maytag PYE2300AY Electric Dryer
Kenmore 63942 Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
