Question about SATO M-10eTT with Cutter Printer
Turning the cutter on and off
Wlhich dip switch is used to turn the cutter on and off on the sato m-10e tt/dt?
  • 54 Answers
DSW3-1, DSW3-2
off off continuous
off on tear off
on on cutter*
on on no used
*defaults to continuous if cutter is not installed
Posted on Feb 25, 2009
Printer ready, Feed option does not working. Other power supply settings printer working properly.
the problem may be in the control panel button itself. the feed button aways works, no adjustments necessary. It's main purpose is to advance the labels.
Jun 27, 2014 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Tip
How to tell the difference between a DT and TT label
Thermal labels come in two main types:
  • Thermal Transfer (TT) - uses a ribbon
  • Direct Thermal (DT) - does not use a ribbon
To find out which material your label is, scratch the surface of it with a fingernail or other pointed hard object. The DT label will produce a mark, the TT label will not.
on Aug 20, 2010 | Office Equipment & Supplies
Feed option not working but printer ready.
Dear jafar,
just first you conform there is no paper jams in your printer then only i will tell it is motor issue///
Jun 18, 2014 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Ativia hd pro 1400 wont turn on
Check the plug and fuse. Check that mains socket is live with another appliance.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
Wile you are there, use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Jan 30, 2014 | Office Depot Ativa DQ60M Shredder
Error condition power supply
Dear,
you have not mentioned, whether print continues with that error or it doesn printer..?
anyway,
first thing, check your power cable.
If that error is on, it means that label media or ribbon sort of errors.
try re inserting both ribbons and media.
if tat error is flashing and printer continues printing, it may coz of over heat of head..! if so try reducing the pressure of the head.
if you are using continous labels, then calibrate the media and ribbon sensor.
for more details, please reach us.
www.trridevlabelss.com
Feb 05, 2013 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
I need to set tear off option in my sato cl 408 barcode printer please help me
Set dip switch 3-1 off and 3-2 on. Recycle power.(Operating mode tear off)
Sep 07, 2011 | SATO CL408e Thermal Printer
Trying to start computer up and I get a diskette drive 0 seek failure message SATO 0 ST3160815as 4.ada SATO 1 HL-DT-ST DVD+/RW GSA-HT3H B103 SATO 2 NONE SATO 3 NONE
Go into the bios of your Dell and ensure that the Sata HDD 0 is being seen by the bios and that it has not been switched with the DVD. Make sure that the sata cables on the main board are plugged in correctly the hard drive should be in sata port 0 and on some dells it's sata port 1. Make sure in the bios that the Sata HDD 0 is enabled.
Hope this helps.
Sep 24, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
What is dip stick setting for dhcp Sato cl412e with ethernet card
You must use the provided software to change the settings. It looks for the printer by the MAC address
Aug 17, 2009 | SATO Cl412e Label Printer
Auto cutter does not cut automatically
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Jun 08, 2009 | Epson TM-U220 Matrix Printer
We have a Sato 480e that prints shipping tickets. It will not print now because it says "Paper End" when there is plenty of paper. I've cleaned the rollers, and changed the paper roll. What else can I try?
check the alignment of the sensor.
If continuous, make sure dip switches are set to continuous.
There are particular settings for a die sut, and continuous label
Dec 11, 2008 | SATO CL408e Thermal Printer
322 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Howard
Howard
WTF Chuck.....
WTF Chuck.....
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
