Question about Durabrand PDV-709
?Can't play anything on my DVD player, Everytime I put the DVD in, it reads, no disc and err disc, what's that? Can I fix this or do I need to take in for service?
  • 1 more comment
  • TheMoolaMan Feb 23, 2009
    No disc and Err disc.
    I cleaned it and it worked for a minute and now I can't get it to work again.
    I called the customer service number provided in the manual. 1-800-315-5885 and it was NOT customer service. It was a rewards center to get me to spend some money. (on the opening it said I must have gotten the number by accident by good luck for me they have an offer for me.( what kind of customer service is that?)
  • archuleta00 Feb 26, 2009
    every time i put a dvd in it tells me error or no disk, i have tried a dvd player cleaner disk to clean the lens and nothing it is still doing the same thing...
  • Anonymous Mar 09, 2009
    when i put a disc in the dvd player says "no disc" or sometimes when i do put it in there is a scratching noise when it is rotating then it says "no disc
Try cleaning it with a q tip and alcohol.  The inside where the dvd actually goes.  The dvd reader and everything can be cleaned and it should work for you.  Hopefully.
Posted on Feb 19, 2009
Err disc
Clean the optical pickup unit by inserting a lens cleang disc into it. If this do not help you, the optical pickup unit need replacement.
May 26, 2012 | Televison & Video
How do i fix my CD player? when i put a disk in, the readout says "err disk" it works every once in a while, but i have run a lens cleaning disk in the player, and it wouldnt even read that disk.
how long have you been using the player? And has it been giving you this type of problem before now?
I think the fault is from the laser (lens) of your player. The lens is very weak such that it cannot read the data or files on a disc, that's why it should disc error, even though it plays some disc but that doesn't mean its not a lens problem.
You need to look for a way to replace the lens for your player so that it can play all discs perfectly well again.
Good luck.
Sep 25, 2010 | XO Vision XO9013 Car DVD Player
Incorrect disc, err when disc is put in,
it is not recogonizing it
meaning you might have a blu-ray instead of a reg dvd
Nov 16, 2009 | Televison & Video
DVD player locks up, won't read discs
its about time you get a new DVD Player...What type is it??? if it is a expensive one it is probably worth getting repaired but if it is a cheapy..then throw it away coz its not even worth looking at...there are the biggest pain to fix!! Best solution is to buy a new one!
Aug 11, 2009 | Televison & Video
I cant play newer dvds why ?
depending how old the player is it might not be able to read dual layer discs
Jun 07, 2009 | Marantz DV4300 DVD Player
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
DVD PLAYER
Hope it was the non-acetone type of polish remover - acetone will melt plastic !!
Invest in a laser eye cleaning disk - the kind with the tiny brushes.
OK what type of file format are the files in on the disk you are tying to play?
IDM-1731 does not like .AVIs.
Check your documentation as to what type of files your player can actually read and play.
Sorry I'm not more help.
DW
Mar 21, 2008 | Initial IDM-1731 Portable DVD Player with...
Err disc
The laser eye is tired(out of alignment) from playing alot of burned disc. Have some one who know re-align it. Goodluck.
Mar 07, 2008 | Dual XDVD8180 Car Video Player
DVD pLayer Not spinning DVD's
if your dvd player is 5 years old or more i suggest you trash it and get a new one but if its not try to clean the lens manually with a peace of bond paper. rub the paper gently on the surface of the lens
Jul 13, 2007 | Sanyo DWM-3500 System
DVD player does not read discs anymore
the Laser is most likely defective. most likly it will need replacement. There is no correction that can made to correct the problem except to that of a replacement of the laser
Apr 06, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Durabrand PDV-709 Logo
184 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
