Question about Onkyo TX-SR502 Receiver
Onkyo TX-SV919THX, No Output
My TX-SV919 lost output about 6 years ago. It turned out to be some internal battery. The shop that replaced it is gone. It now has the same problem, no output. Does anyone know how to fix this problem?
I have found the battery location. It is roughly on the opposite side of the pc board where the display is. It basically faces the heat sinks. It's one of those small watch sized batteries and is soldered but sticking off the pc board with 2 leads. I could see that there was some leakage and corrosion. I still have to figure out what needs to be dis-assembled to get access to it so I can unsolder the bad battery and replace it. This stupid little battery seems to need replacing every 6-8 years! When it dies, it seems to disable the preamp section from passing any signal giving the symptoms that the amps are dead. However, if you try to use the pre-outs to an external amp, nothing. So, my guess is it has something to do with the preamp section. Anyway, that will be my weekend project to try to get at the battery and replace it with "longer leads" so it will be easier to replace in 6 years when it dies again. Great design Onkyo! You dumb-*** weasels!!!! I hate when companies engineer things to break so you are likely to pay them to fix it. Not this time, "No soup for you!"
Posted on Feb 19, 2009
No output on my Onkyo TX-SV919, please let me know whats wrong with this receiver
Hello, I am sorry about your issue. It would be difficult to determine where the problem lies. I suggest having the unit serviced or traded in. Thank you, Onkyo USA
Apr 25, 2017 | Onkyo Audio Players & Recorders
Onkyo tx-sr500. No output to surround speakers.
Need to be diagnosed my serv tech. This could be many thing. Most Onkyo receivers have 3 year warranty.
Mar 25, 2010 | Onkyo Audio Players & Recorders
Onkyo TX8211
The most likely problem is shorted output transistors. This is a straightfoward repair for any shop that works on audio gear. Expect a parts cost in the $40-$50 range.
Dan
Aug 12, 2009 | Onkyo TX-8211 Receiver
Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Apr 09, 2009 | Onkyo TX-SR701 Receiver
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Onkio receiver
The output transistors should be replaced in pairs. Also, It may not be just the output transistors that are defective. If you have no experience with these types of repairs, I would suggest that you bring the unit to a service shop. The outputs will run about $15-$25 per pair.
Dan
Aug 29, 2008 | Onkyo TX-SR601 Receiver
Lost right channel of CD
This service manual is available here http://www.manualscenter.com/onkyo-c-74.html?page=14&sort=2a. The cost is 10 bucks or 15 bucks, depending on if there is an X at the end of this model number or not.You will need to check the final output stage for an open circuit, possibly a shorted output device or a drive IC or transistor. First open this unit and make sure there are no open channel output fuses. Some models have these. Not sure about this model. Good Luck
Mar 21, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-SR502 - o Sound!
pls make it reset at factory level ,but pls note that you have to keep it in aauto mode
Mar 12, 2007 | Onkyo TX-SR502 Receiver
Onkyo TX-SR502 Receiver Logo
1,825 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
