Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Need to change keypad access code for Sears garage door opener
Need advice
  • 18 Answers
To change the code, you need to hit the LEARN button the back of your machine. You will see a yellow light flash. Enter a 4 digit code on the keypad and press enter. The lights on the opener should flash and you should hear a click. Your keypad is programmed.
Posted on Feb 19, 2009
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
Hello I have an Access Master Chamberlain garage door opener and i never had to change the garage code. Can u assist me in changing the code?
Well I have to assume you want to change the code for the keypad because that is the only code you can actually change. Locate the smart/learn button on the rear of the motor unit near where all the white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Jun 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
We have just bought a home. I need to change the code on the Sears Wireless Keypad for the garage door opener - this is located on the outside of the garage. What keys do I need to press to change the...
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you change the access code for the 53975 craftsman garage door opener thanks
If you mean the code for the keypad do this:
Press and immediately release the smart/learn button on the rear of the motor unit near where all those white wires go and then walk over to your keypad and key in any 4 digit code you like and press enter.
Oct 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change code
If your opener has a wireless keypad it should be simple. On the back of the motor unit you will find the smart/learn button. Press and immediately release it and walk over to your keypad and key in any 4 digit code you like and press enter.
Jun 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
May 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftman Garage Door
I enrolled in the Assistant Premium Plan and am waiting on a response.
Apr 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Trying to add temporary code to craftsman keypad for Sears garage door opener.
Yes there is you need to press the colored learn button on the motor head and then follow the directions on the keypad. Thanks BB
Jan 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,165 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
