Question about Toshiba Televison & Video
Toshiba tp48d50 has vertical red wavy lines on
  • 184 Answers
These Toshiba TVs are well known for convergence problems. When you put the convergence test pattern on the screen, does it appear normal? If there are curves in the crosshair lines and colors flairing from them, you have just such a failure. The convergence output ICs will have to be replaced. You'll spend $300-$450 to have this fixed.
Posted on Feb 19, 2009
Toshiba hyper module. Vertical lines on screen.
change the 10 or so surface mounted bad filter caps in the Hyper module this set uses--the board is no longer available--it can be sent out for rebuild (not toshiba) but that is rather costly (200+)
Oct 28, 2012 | Toshiba 57H81 57" Rear Projection...
Red and green wavy lines
chek your power in if it is stabile than you musht range a power stabulisator othervice if is ok need chek in to change crystal diodes and aom other parts
Jan 22, 2010 | Toshiba Televison & Video
Toshiba Rear Projection TV Picture Problems
The convergence circuits need to be replaced Sometimes it is just the matter of 4 capacitors and an IC but often than not ythe whole board has to be replaced.
Sep 02, 2009 | Toshiba 57HX81 57" Rear Projection...
About two months ago when we first turned on the TV there were wavy lines across the whole picture. When it warmed up they would go away. Now, the lines are there almost all the time and it's getting...
You are experiencing a lack of vertical deflection or vertical collapse. Since it will come back the first thing I would suspect is “ring cracks” in the solder joint in the vertical circuit, mainly the vertical IC. These suspect solder joint can be re-soldered and the television set repaired.
I would suggest that you contact a local servicer. If you are repairing the set yourself, be careful, there is always a risk of shock when dealing with electronics.
Check your equipment connections. Disconnect your equipment (VCR, DVD or set-top box) from the TV and reconnect, making sure each connection is in tight.
chek this site,i blieve u will b helpfull
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
Picture is wavy and has black vertical and horizontal band
The following are supposed to be checked on the horizontal and vertical,
the supply of the sawtooth oscillator
eletrolitic capacitors near a line transformer
zener diodes
and driver transistor a round that area.
Apr 08, 2009 | Toshiba 35A44 35" TV
Red vertical convergant line
You need to replace the two Convergence IC's and associated resistors. All the information you need is contained in this link
Jan 19, 2009 | Hitachi 43FDX01B TV
convergence Ics you will need two STK392-120 convergence ICs. You can get replacement ICs at the following link with free instructions.
Jan 19, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Toshiba Projection TV 14 years old model tp48d50 there is a green line on bottom of tv How can I fix this
thats going to be something to do with your convergence.if you think its worrth it take it to a shop but usually after 10 of age they start to act up and that sounds like yours maybe be ready to be replaced
Dec 28, 2008 | Toshiba 50HX70 50" Rear Projection...
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Televison & Video Logo
213 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
