Question about Samsung HL-R6167W 61" HDTV
Samsung Model HLR6167W
I have a samsung 61" tv Model HLR6167W and it is about 2 years old I have replaced the lamp and color wheel already and I have sound but no picture...Can anybody help????
  • 52 Answers
Does the lamp light if not and you are sure you have a good lamp check the ballast and make sure you have voltage coming from it.
Posted on Nov 14, 2009
    Novelist:
  • 184 Answers
Does the TV appear to be cycling on and off, like its attempting to boot up? Or, does it just not come on at all? Don't miss the lamp door interlock switch. Many Samsung DLPs have tempermental door switches. Try re-installing the door or manually hold the switch in the closed postion and try to power it up. If the lamp comes on and stays lit, you've found your problem.
michtech
Posted on Feb 19, 2009
Is it possible to have only the red tint projector lamp replaced on 61" projector Samsung tv
No. This is a DLP TV. It gets it's color by a color wheel. If color seems to drift across screen or there is a loud-ish whining noise from back of TV that you can here clear across a room, then this color wheel may be bad. They wear out.
Jan 07, 2015 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w TV Dlp lamp won't turn on already replaced lamp, ballast, color wheel
It sounds like the main power supply has a bad capacitor. its a typical issue with a lot of electronic. look on the main power board that the outlet cord comes in to the TV and check all the cylindrical components for swelling, leakage, or singe makes.
Dec 13, 2013 | Samsung HLN617W 61" Rear Projection HDTV
I cleaned out my Samsung hl-s6187w and put everything back together and now it doesn't turn on. It makes a beeping noise like fast morse code and keeps cycling the power trying to turn on. The ballast gets...
Tv projection lamp inside the tv less than 2 years or so?Yes than the tv projection Lamp is good.You have this tv like 3 or 4 years already?The tv colors wheel even have been replace at leat once?No the tv probally require replacing the colors wheel these tv have to replaced the colors wheel every now and than.
Apr 14, 2011 | Samsung HL-S6187W 61 in. HDTV
I believe it'ds time to replace the bulb on my hlr6167w It is 4 years old. I took the 4 screws and thd removed the plastic backing. How do i removeve the bulb? I need to give best buy the bulb #
Look at the Lamp Module and you will see ONE gols colored screw. Remove that screw,then gently wiggle and pull out the Lamp Module. Look into the center of the lamp and you will see shattered glass or a white powder inside,If so replaced the lamp. The Lamp Code is located on the Left side of the set. It is a sticker labeled Lamp Code. Order a Lamp by this code. Replace the lamp in reverse order and reinstall the lamp Door with all four screws.
Apr 02, 2010 | Samsung HL-R6167W 61" HDTV
Samsung 61' DLP Color problem.
If you are using Component inputs, check to make sure that the Blue Video Cable has not backed out of its connecting jack at either end or the cable it's self being bad. If you are using HDMI I would suspect that the Digital Board being bad. It would be odd for the Color Wheel to cause the problem but cannot eliminate it as a cause. The Lamp would cause the picture to be darker but not cause a color to drop out.
I would call a professional to trouble shoot it unless you have the knowledge and the tools to do so.
Hope this helps,
Skyassoc
Jul 04, 2009 | Samsung HL-P6163W 61" TV
My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Dec 14, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
61" samsung DLP
The original lamp code number and color wheel part number must match...give me all the # ' s for research = Model # , lamp
numbers,color wheel numbers,etc.
Also, does it "melody" on and " melody" off ?? That is a function
of DMD module = might be defective...............T,
Dec 20, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HLN617W 61 i
it is not related to the failure of the fan or color wheel by anything other then the age of the set..the lamp has a normal life of 4000 to 6000 hours and since your set is around 3.5 years old it probably has that amount of time on it..the lamp is consumer replaceable and many places sell them..the lamp number should be on a small sticker on the side of the set
Dec 02, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HL-R6167W 61" HDTV Logo
646 people viewed this question
Jerry Greenberg
Jerry Greenberg
