Question about Toro "Toro" Electric Rake & Vac
While using the blower, the motor slowly died. Now no power at all
  • mhanson Feb 23, 2009
    I decided to go ahead and purchase a new one, thank you for trying.
How do I check resistance on a 1998 Chrysler Concord auto climate control heater
You can check for continuity of the blower motor by unplugging it and putting your test leads on the terminals of the blower motor. I'm thinking less than 2-3 ohms.
If your trying to check the blower motor module than set your voltmeter to a/c (NOT D/C) voltage. Ground lead on any good ground. The positive test lead will back probe the red with light green wire at the ATC power module. Turn the blower motor speed up and down slowly. You should see the A/C voltage go up and down. If it does and there is no power going to the blower motor and there is power on the dark green wire at the ATC module than the ATC module is bad.
Nov 13, 2014 | Chrysler concorde cover. blower motor. ....
I have a Red Max HBZ2600 Z Power blower that starts runs a few minutes then slowly dies. Fixable?
Install a new spark plug
Clean or replace the air filter
Use only gas that is no more than 2 months old
& add fuel conditioner such as Sta-Bil or B&S,
unless you have to mix fuel for a 2 cycle motor
Once running & fully warm,adjust carb screws for
fuel mix at idle & fast rpm, then set the idle
Check for spark with a small engine tool avail for that
It looks like a spark plug with a clip on it & avail many places
May have to remove the carb,clean it & install a new kit,if
you still have problems
Jun 09, 2014 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Hyundai Engine dies when A/C-heater blower is switched on. Is it the resister motor?
i would think it might have more to do with the alternator charge rate ,as the A/C use a lot of engine power so the other components get reduced power from the engine ,so the alternator raises the power to the battery and so to the other electrical components,if the charge rate is low the engine can die ,does it start ok when A/C is turned off ?
May 12, 2014 | Hyundai Accent Cars & Trucks
Fedders 5,000 btu window room a/c; blower won't run or runs very slowly. When it does get up to full speed, it only runs for a short time (10 or 15 mins) then blower stops.
Sounds like the motor is overheating and stopping after some run time has passed.
The issue with it not wanting to get going sounds like it may need oiling (if the oil type). Or it could simply be the motor is on it's way out and will soon die on you. In the latter event you sound like you need to replace the motor.
Sep 02, 2010 | Heating & Cooling
95 subaru legacy had the blower quit about a week ago, had no power to the motor so i thought it was the relay. then the speedometer, tachometer, odometer, and temp gauge quit working. I tried to get home...
do you have battery power will the car turn over
there is a set of fuses in the engine compartment check these as many cars have a system that allows the car to run till the battery dies check your alternator
Mar 03, 2010 | 1995 Subaru Legacy
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Blower motor has power but does not run does it need a high blow
if the resistor you refer to is the capacitor, yes it dies require the capacitor and no it cannot be bypassed. I fyou have power to the blower and it does not start you need to replace the motor.. hope this helps
Jul 31, 2009 | Heating & Cooling
Blower motor runs but dies out..
When it does this carefully feel the end of the blower motor. If it is too hot to touch,Replace the blower motor.
Your 5 minute off sequence allows the motor to cool enough for a restart.
Apr 08, 2009 | Amana PTH153B50AJ Heat Pump Air...
Speed of mixer
does the motor still run or does it slowly start to get less loud? or is the beater assembly that dosnt work? two different issues. if the motor runs but dosnt beat then its the planitary gears that are ground out and need replacing. if the motor slowly dies out then you need to replace the motor.
Dec 24, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Toro "Toro" Electric Rake & Vac Logo
87 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
