Turns on by itself
Hi i have an email air ducked it is 13 years old had no probs with it, but it now turns it self on and i can not turn it off or control it from the pennel with out seeing it could it be the pannel on the wall
  • 51 Answers
This problem can very well be your thermostat, or exposed thermostat wiring.
Posted on Feb 20, 2009
  • Kent Guidry
    Kent Guidry Feb 20, 2009
Noma model ew7507ce
There is a thermal disc inside the heater that will tell the heater if it is getting too hot to shut down. When the disc cools off then the heater will start up again. After a wile the disc gets weak or it gets stuck open not allowing the heater to turn on. You will need to replace the disc or purchase a new heater as parts for those are not easy to find.
good luck
Apr 14, 2014 | Honeywell Heating & Cooling
Ge front load dryer
Your issue probably causes by vent duck was blocked either at the rear or from inside the duck. Take off the vent where it hooks up to the rear of the dryer. Turn on the dryer, if it works with hot air again then you have to clean your vent duct. Else, you need a service man to find down what is wrong with the thermostat, burner, etc...
Oct 15, 2013 | Washing Machines
I have a 5 year old RUDD heater. Burner turns on for 5 seconds then shuts off. Air filter was plugged. Replaced last week and thought prob was solved. Prob is back now. Tried pulling new filter out a...
Hello,Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Feb 28, 2011 | Heating & Cooling
My gas oven wont light
The ignitor that lights the burner has failed...
Checkout this tip that I wrote...it will help uou understand your problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 04, 2010 | GE Profile 30" Self-Cleaning Freestanding...
Aquos turned itself off and won't turn on again
hi....Your micro chip is faulty check the voltage comming out of the 42nd leg it shuold be 13 volts dc if you are not getting that voltage replace the microchip.and the eeprom IC....
thank u rate me!!
May 24, 2009 | Sharp Aquos LC-15E1U 15 in. LCD EDTV
I have a GE self-cleaning radiant range about 13 years old. The self-cleaning feature doesn't work anymore. The latch doorlight, even though set correctly to the right,keeps flashing on and off and the...
It could be a micro switch in the latch mechanism not communicating properly with the display circuit board, or it could be the circuit board itself. The switch might cost 20 or 30 dollars, but the board could be hundreds. Kinda costly if you ask me...
Mar 13, 2009 | GE Kitchen Ranges
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
